Bad D Day
CNESLER
08-19-2007 07:56:36
I decided to overhaul our 1952 D. I had the block
sleeved back to standard. The problem is as I turned the crank to torque the rod bolts the oil ring came out of the block on number 1 cylinder
which of course locked the engine. What could I have done wrong?
Thanks
CNESLER
Ron in N.E. Colo
08-20-2007 17:24:00
 Re: Bad D Day in reply to CNESLER, 08-19-2007 07:56:36
Let me preface my remarks. In the last 30 years, my tractor collecting neighbor and I have probably had 25-30 JD d tractors apart for restoration or just to overhaul and sell. I have never seen a set of insert rods in one out here. All we have had apart were babbited rods. This could make a difference if he had the crank turned down. Now here is one that will surprise you, I have seen JD piston sets with the same casting number on the piston, but the oil ring was not located exactly the same distance from the bottom of the piston. I know that they moved the pin location slightly on some of the later pistons. In 30 years of manufacture, there were small changes in the pistons and rods. Maybe this will help. By the way, wasn't there a discussion a few months ago about a gentleman in Texas who had the same problem? What was the outcome of that discussion?
Will P
08-22-2007 17:35:53
 Re: Bad D Day in reply to Ron in N.E. Colo, 08-20-2007 17:24:00
See, told you. We will never hear from him again.
Will P
08-20-2007 18:12:12
Like most posters here, we will never hear from them again. If we do ever here back, I would be surprised. You know more about this than me it seams. So I am out of here. I will take my machining ability and leave.
bye
Will P
08-20-2007 15:31:05
Ron in N.E. Colo, wants to know if you did anything to the crank. Does the whole ring fall out of the block? Or does it fall out of the sleeve? Feel if there is a step at the bottom of the block, where the ring falls out.
Ron in N.E. Colo
08-20-2007 09:49:16
He states that the oilring comes out of the BLOCK, he doesn't say that it comes out of the sleeve. I am only going by what the message says. How could it come clear out of the BLOCK unless something has changed with the crankshaft, and if they are the same pistons? By the way, are they insert rods or babbitt, and did you have anything done to them?
Will P
08-20-2007 15:33:29
 Re: Bad D Day in reply to Ron in N.E. Colo, 08-20-2007 09:49:16
I know what he said, and I know what is going on. I am going to say he never noticed a step at the bottom of the block. I bet it doesn't fall out of the block, but passes the step of the sleeve. We will see what he responds with.
JBiff76
08-20-2007 05:53:00
I had a similar problem with a GP block back in 2001. I agreed to purchase A block (from a reputable person) sleeved back to standard. When I got the block I noticed that the sleeve stopped about 1/2 inch from the end. I realized that this would not work and called the man. He then called the machine shop where the work was done and their reason was that that was as long as their boring machine would go and they did not think it was a problem. I sent the block back(no s&h out of my pocket). It then went to a diferent machine shop and the old sleeves were pushed out, new ..correct boring was done, new sleeves installed and today the GP runs great. WHAT AN ORDEAL. Good Luck. Jon B.
Bob-Wyo
08-19-2007 13:01:42
Didn't by chance forget the front half of the rod bearing shell? If not I agree with Will P, does the sleeve come all the way to the back of the block? (should be even with the main case)
I would do what 730-LP said, even had a guy tell me once that his Dad always pulled the oil ring's off when he was going to do a lot of heavy plowing.????? ??
Bob
Ron in N.E. Colo
08-19-2007 09:12:27
If the oil ring came completely out of the block, it is not the sleve.Did you have the crankshaft turned down? Somehow, you are moving the piston farther back than before.
Kemper
08-19-2007 16:52:24
 Re: Bad D Day in reply to Ron in N.E. Colo, 08-19-2007 09:12:27
I would be a little ticked about that...
I bet they ordered the wrong sleeves, what else could have changed that much...
Let us know what you find out.
Will P
08-19-2007 14:43:19
What??? 1st, you state "If the oil ring came completely out of the block, it is not the sleve" Why do you say that????
2nd you state "Did you have the crankshaft turned down? Somehow, you are moving the piston farther back than before. " First, if he had the crank turned down, say .030 that is .015 on a side. So the crank would be pulling the piston and ring .015 further back. The rings on a D are .250 thick. The piston pulls half, or .125 of the ring out of the bore. He would have had to have turned off .250 or quarter an inch total off of the crank to have the ring fall out of the bore. Turning the crank to a common replacement bearing size would have no affect on the ring falling out of the bore.
I stand by my statement, the sleeve is to short. It needs to come to the bottom of the bore. I bet it isn't.
By the way, I am a CNC machinist.
Will P
jjas
08-19-2007 17:58:50
 Re: Bad D Day in reply to Will P, 08-19-2007 14:43:19
Unfortunatly Will P is correct on the sleeve however, he is incorrect on his crankshaft adding more stoke just because it is tuned down. That is not possible since the bearings are now thicker to take up the smaller diameter of the crank journal the pistons move the same distance as before.
Will P
08-19-2007 18:29:31
 Re: Bad D Day in reply to jjas, 08-19-2007 17:58:50
You are correct. I will give you that. But, I never stated it would make a longer stoke. I just forgot about the bearing taking up the machining. Which would put the piston back to the original spot in the bore.
Turning down the crank will never change the centerline, unless you offset grind it. But machine shops wont do that unless you tell them. And it sounds like he is just trying to restore it and not stroke it.
Peace!!
Will
Will P
08-19-2007 08:14:15
The machine shop sleeved the engine short. You will have to have them fix it. They did it wrong!!!
730-LP
08-19-2007 12:41:07
 Re: Bad D Day in reply to Will P, 08-19-2007 08:14:15
Remove the bottom compression ring and move the oil ring up to that grove.A lot of pull tractors are run that way.works fine
