Anyone own or seen a Lindeman with adjustable V-plow?
Lindeman
08-18-2007 20:02:30
third party image
Has anyone seen or own a Lindeman like that pictured here? I have an early flatback with this same V-plow and hydraulic lift driven by the flywheel. It also has wider pads 14" vs 12" seen on other Lindemans. Anyone else have wide pads, adjustable v-plow or hydraulic pump driven off of flywheel on theirs?
Previous owner claimed this one was suppose to be sent with some others for military use-wondering if any truth to that-if that same v-plow and hydraulic setup were only used on those also. Tractor also has numbers stenciled on hood under the layers of paint and a small tag with a similar number welded on blade.
Thank you for any help or info or old pics of these Lindemans that were used for the military. I'm aware there was a BI Lindeman built but not interested in info for that one.
95CS
08-20-2007 13:42:08
 Re: Anyone own or seen a Lindeman with adjustable V-plow? in reply to Lindeman, 08-18-2007 20:02:30
Have you tried www.lindemanarchives.com ? They might be of some help to you.
dlplost
08-19-2007 09:16:18
third party image
YUP, NY JD Expo just a month a go...
Lindeman
08-19-2007 16:38:29
 Re: Anyone own or seen a Lindeman with adjustable V-plow? in reply to dlplost, 08-19-2007 09:16:18
Thanks for the pic. Did that one have a hydraulic pump by the belt pulley to lift it? Maybe it is a later one, the lift arms that extend out to lift are different and also the frame on the tractor is slightly different compared to the one in the pic and the one I have.
Any other pictures of different ones by chance? Thank you.
