4020D replacing Generator to Alternator
Brian Setlak
08-18-2007 19:06:52
I have a 4020D and the generator has not worked for years, I"m finally tired of charging the batterys up every time I need to use it. I"d like to convert it to a GM sytle alternator. Mainly because they are cheaper to replace. The wireing is also in very bad shape on the 4020 so I have lots of work to do, I have the hood and loader off so nows the time.
So were should I start, are there any kits, can I just pick up parts at the junk yard and do it my self? It"s a 24volt starter, other than that everything else is gonna have to be replaced.
Del 1940
08-22-2007 11:06:22
 Re: 4020D replacing Generator to Alternator in reply to Brian Setlak, 08-18-2007 19:06:52
The easiest way Ive found (it's not the cheapest) is to get a 12V starter from a newer 4020 (1969 or 1970) with a 12v system. With the alternator you'll have a negative ground system. So you'll have to get new battery cables and run the positive cables to the stater off both batteries and the negative cables to a grounding point on the tractor frame. As in the previous post, this will not keep the batteries charged if you have a short in the wiring system.
Gerald J.
08-21-2007 09:15:40
You need a Leece-Neville truck alternator that has both sides floating. The common GM alternators are built with a solidly grounded negative and are not commonly made to float like the 4020D needs. There have been GM alternators built to float, but very few though that includes the ones Deere had for the 4020 with cabs and airconditioning. There is a Deere part number but my parts manual is too far down the pile to dig it out today.
Gerald J.
Brian Setlak
08-20-2007 03:58:54
Thanks for the ideas guys. I'm in Michigan and going from 24 volts to 12 with our cold winters kind of concerns me. I did look up the 24to12 conversion here on YTMag, little salty. Kind of was looking for a cheaper way out. I've always had troubles with generators and have seen GM style alternators on 4020s at auctions and thought it must be a better idea and cheaper, looks like it might not be.
Thanks again
msb
08-19-2007 11:23:40
Easiest to just buy the kit unless you have more than a basic knowlege of 12/24 volt tractor wiring systems. Kit comes with very good and easy to follow instructions.
http://www.ytmag.com/store/parts/convcat.htm
R. John Johnson
08-19-2007 08:10:08
I think you will be pleased with the 12V conversion. Many places sell them, this site for one. Things to think about are....
1)you may also need to replace you fuel gage and sender. The original system used 12V Positive ground on that circuit and it will not work with 12V negative. If you have replaced some of those parts already, you might be OK.
2) converting to 12 Volts will not cure any flaws in the rest of the electrical system. Dead shorts in the wiring will still drain the batteries.
3) When you go to replace your fan belt, the original part from JD may not fit. At least it didn't on mine.
4) whichever system you use, replace the existing battery cables with custom made ones using 2/0 wire and soldered on ends. I did that to mine just this year and WOW! does she ever turn over now!
No offense to SwedeDeere, but I would rather replace the starter than try to get a 12V negative for running and charging, but a 24V starting system. Worst case is buying a used starter from a wrecker for a couple of hundred bucks.
Good Luck!
John
GeorgiaHayFarmer
08-19-2007 04:56:39
You can get your GM alternator converted to a 24 volt. Ask your alternater shop about that one. We have a fella down here in Geogia that knows how to get it done.
Scott
Roy in georgia
08-19-2007 14:28:34
 Re: 4020D replacing Generator to Alternator in reply to GeorgiaHayFarmer, 08-19-2007 04:56:39
hey Scott is the guy you use in Thomaston? Railey's rebuilding? Mike owns it and knows what he is doing his father started the business long ago and mike took it over completely about 6 years ago.
GeorgiaHayFarmer
08-19-2007 16:54:22
 Re: 4020D replacing Generator to Alternator in reply to Roy in georgia, 08-19-2007 14:28:34
Hi Roy,
The fella I was referring to is up in Palmetto, Ga, just North of my place. I was at the tractor show with him and he was telling me how he converted one to 24 volt. He has been working on them for years and grew up on a farm plowing and cultivating with Allis and John Deere tractors.
Scott
Roy in georgia
08-19-2007 17:34:30
 Re: 4020D replacing Generator to Alternator in reply to GeorgiaHayFarmer, 08-19-2007 16:54:22
Does that guy rebuild alts. for a living? If you ever need one rebuilt this guy can get the job done he just rebuilt my starter for my 1010 it needed a new armatuer cost me $67.80 with new brushes. I checked on one at Napa and it was over $150 rebuilt
SwedeDeere
08-19-2007 02:45:14
It is a very good idea to use a GM 12 V alternator. Did that myself, and it works perfect. Since you are rebuilding the electrical system just build a normal 12 V neg ground system for everything, except for the starting cicuit. Since the starter neeeds 24 V (if not repaced with a 12 V unit), you have retain the battery with pos ground for the starter. But the battery with pos ground will not be charged by the alternator. There are four ways to to that:
-use a DC/AC converter and battery charger connected to the pos ground battery
-mount a pos ground generator below the alternator, driven from a double pulley at the alternator
-have the "pos ground battery" connected to neg ground for charging (to the normal system). When used for staring disconnect the battery from the neg ground system and connect it with pos ground for starting. This can be done with a multi function switch plus relays or fully automatic, with a couple of extra relays/contactors. -the easy way, keep the battery connected to pos ground and use a battery charger now and then, not very often.
Bob
08-19-2007 09:46:11
 Swede, in reply to SwedeDeere, 08-19-2007 02:45:14
You ARE kidding, right?
Roy in georgia
08-18-2007 19:38:04
Brian if you have a rebuild shop near you let them give you a price to repair the gen. I have heard that it is expensive to totally rebuild a gen. but I had mine looked at and all it needed was brushes. Take the regulator with it as they can test it also. I,m not sure about the 24v system but a 12v alt. that is set up to work on a tractor is around $65 at my rebuild guy. with one set up right internally all you have to do is run (one wire) from the post on the back of the alt. to the battery. If you would like to contact my guy he is in Georgia but I am sure he would ship to you or even check your gen. out if you ship it to him
