H john deere weight
Mike w J
08-18-2007 17:15:43
About how much does an H john deere weigh with electric start and steel front wheels not cast ? THANKS Mike
Green Relics
08-21-2007 05:09:05
 Re: H john deere weight in reply to Mike w J, 08-18-2007 17:15:43
Hi Mike W j, H tractors that I see at the local tractor pulls are all just under 2500 lbs. Thats right on the scale.
Duane Larson
08-19-2007 12:17:29
 Re: H john deere weight in reply to dan_41jdh, 08-19-2007 11:00:16
Hi Dan,
My guess is that the weights published in the Price Lists have to do with estimating shipping/freight costs. So, the engine oil and transmission lubricant are likely included, but not water (drained for cold weather) or gasoline (too easy for the RR bums to drain and use).
I completely agree with the necessity of providing references to the sources of information provided in answers (as appropriate). Often, as in the case of HP, there are several correct answers.
dan_41jdh
08-19-2007 13:40:09
 Re: H john deere weight in reply to Duane Larson, 08-19-2007 12:17:29
Thanks for the response, Duane. I suspect that your assumptions are correct, but it would be interesting to see some confirming documentation someday regarding just what those published weights really reflected.
Anyway, I guess one shouldn"t be too concerned about the "exact weight" because it"s there were probably no two H"s that weighed exactly the same anyway, due to variations in material thicknesses, etc., not to mention tire variations and other variables.
As an interesting story to emphasize how much actual weights of manufactured items can vary, there was an article in the Wichita edition of the "Boeing News" (corporate newsletter for employees) some 16-17 years ago that described a new program that encouraged employees to control the final weight of commercial 747 aircraft. (The empty weight of a 747-400 is almost 400,000 pounds!!) The article described an analysis that showed employees could control many TONS of weight of the finished aircraft by simply ensuring that each of the millions (yes, millions!)of parts in each 747 were on the minimum end of the tolerance spectrum. For example, the analysis showed that if all the rivets were made toward the shorter end of the acceptable tolerance (instead of being long, but still acceptable), a tremendous amount of weight could be saved. Same thing with staying on the thinner side of the allowables for material thicknesses. And, they showed how slobbering on excessive amounts of adhesives also added remarkable amounts of excessive weight to the finished aircraft.
Why was all that a big deal? According to the article, final delivery weights were critically important to the customers (United, Northwest, etc.) Apparently, maximum delivery weights are negotiated at the time of sale. If an aircraft is delivered and exceeds the negotiated weight, Boeing gets socked with a penalty because that aircraft will be forever doomed to carry around that excess weight which translates into significant extra operating costs (fuel) for the life of the aircraft.
Anyway, that was an interesting example of how finished weight of manufactured products can vary, and sometimes can vary a surprising amount.
So, without actually weighing one"s tractor on a certified scale, and allowing for fuel and other variables, one really doesn"t know how much the tractor actually weighs. Published values don"t always show the entire spectrum.
Duane Larson
08-19-2007 07:52:45
Mike,
From a 1945 Deere Price List from the Omaha Branch House the following weights are given:
Base tractor with pressed steel fronts and 9-32 rear tires 2141 lbs
add starting and lighting 78
add manually controlled shutter 6
add power shaft (PTO) 37
add power lift 62
add duplex control for power lift 28
Since Deere didn't provide batteries - that was done at the dealer - you'll have to add the weight of a battery. So, you can pick and choose among the options on your tractor to arrive at the weight from the factory.
P Browning
08-18-2007 18:44:27
I think the 3000 pound value is a little high. I would extimate its weight closer to something under 2400 pounds. The 39-H weighed in just under 2100 -- one reliable source says 2063 pounds. Now if you loaded the beast up with weights and/or fluid in the tires, yes -- you can approach the 3000 pound mark. My best to you! (PatB)
David in TN
08-18-2007 18:34:32
about 3000 lbs
