I've Found 2 JD 60's at same farm, where do I start?
Doc
08-18-2007 17:13:25
It"s been a loooong time since I"ve been here guys... been too busy with starting a business 3+ years ago. Well, I need an outlet so I started looking at tractors again.
I"ve found 2 1953 JD 60"s. They both run, are in fair condition, have been used quite a bit. Rubber good, sheet metal fair. Live hydraulics on 1 of them. One is a round tube WF (WF is in solid condition, no welds). The other is has ROM front end. Both have loaders that should be scrapped. The WF has a noisy tranny in 2-3 gears.
I"m just looking for a range here, I know that it"s a question that some users here get irritated with... but any starting help would be appreciated.
I live in NW Minnesota.
Thanks,
Tom (Doc)
DP
08-18-2007 21:26:52
 Re: I've Found 2 JD 60's at same farm, where do I start? in reply to Doc, 08-18-2007 17:13:25
I don't know where your located, but I would zero in on the one with live PTO and hydraulics. You don't say which tractor has the wide front, but in this area of Kansas a tractor like that with ROM front and no power steering will run $800 to $1000 dollars. Good Luck on your venture. Don
ronco
08-18-2007 17:56:56
I think all 60s have live hydraulics but live PTO was an option. $1500 would be a good starting price where I live.
Doc
08-18-2007 17:15:07
I should at least clarify that I am looking for starting PRICE to offer the gentleman.
buickanddeere
08-18-2007 22:15:20
 Re: I've Found 2 JD 60's at same farm, where do I start? in reply to Doc, 08-18-2007 17:15:07
$2500 for both together. The 60 is twice the tractor any old A ever was.
Kemper
08-19-2007 06:13:08
 Re: I've Found 2 JD 60's at same farm, where do I start? in reply to buickanddeere, 08-18-2007 22:15:20
I wouldn't say the 60 is twice the tractor as an A, actually it is an A,with more options.
I bought a 1956 60 last winter, clean tight tractor for 2900.00 with loader,yes it was a little on the high side,but it does not need anything replaced at all.I'd rather pay a little more up front for a tractor that has been well cared for.
wilamayb
08-19-2007 07:07:50
 Re: I've Found 2 JD 60's at same farm, where do I start? in reply to Kemper, 08-19-2007 06:13:08
Kinda... A "plain Jane" 60 could have been ordered so that the only option it would have over an A would have been the live hydraulics. No powersteering and no live power, however there were some internal updates that made it questionably a better tractor.
buickanddeere
08-19-2007 14:07:28
 Re: I've Found 2 JD 60's at same farm, where do I start? in reply to wilamayb, 08-19-2007 07:07:50
duplex carb too. Water pump although late A'S had them too.
