4230 quad range
Steve66
08-18-2007 13:31:20
When I try to start my 4230 I have to move the gear selector around to find the right spot for it to start. How do I fix this problem?
Steve
G/MAN
08-19-2007 16:13:05
 Re: 4230 quad range in reply to Steve66, 08-18-2007 13:31:20
You might have to adjust the actual shifter linkage or even the switch itself. The problem is not necessarily between the shifter cam and the switch. It could be that the linkage and shifter are worn enough so that the cam isn't fully in the park position when the lever is. It's best to follow the entire procedure in the manual and double-check that the tractor will only start in park after doing the adjustments. It's possible to get things out of whack so that the neutral start switch is more or less bypassed completely and will allow the engine to crank in other positions besides the true park position.
lonzo
08-18-2007 23:04:36
the saftey switch is located on the upper right side of transsmisson case and has a flat plung, unscrew the switch and remove the shims and put the switch back in and off you go. if it is a power shift the switch is on the shift valve and same side, sometimes the shifter arm (quad range) needs drove on the shaft tighter, loosen the 3/8 bolt and pull out on the arm and tape on the arm to drive in back on the shaft, lock the bolt and your good to go
