3020 Powershift oil level
ponchobro
08-18-2007 12:51:40
Hello, My neighbor just got a 3020 JD Powershift. Could you please tell me the correct way to check the hydraulic level????? THANKS!!!!
G/MAN
08-19-2007 16:14:26
 Re: 3020 Powershift oil level in reply to ponchobro, 08-18-2007 12:51:40
The tractor should be sitting on a level surface and the rockshaft/hitch should be fully lowered. Checking the oil level with the hitch raised and adding oil will cause the tractor to be overfilled.
msb
08-18-2007 18:03:45
Unscrew the dipstick, Wipe it clean and just set it down on the threads, Don't screw it back down. Pull it out and see where the oil level is on the stick. Filler neck cap is just above and to the rear of the dipstick.
ponchobro
08-19-2007 04:34:54
 Re: 3020 Powershift oil level in reply to msb, 08-18-2007 18:03:45
Is this with the tractor running or not???? Thanks
T. K. in PA
08-18-2007 15:22:38
should be dipstick on platform under the seat
