JD 3140 Hydrulics
Stephen McCurdy
08-18-2007 11:23:35
I have a JD 3140 which is fine up to 1500 RPM after this the hydrulic pump starts to hammer badly on the main line to the valve bank (beside oil filter). The rear brakes have been replaced and system flushed - refilled with new oil and filter. Tractor seemed fine for a day but started to hammer again - a second new filter was installed but to no avail - Any suggestions???
buickanddeere
08-19-2007 14:11:08
 Re: JD 3140 Hydrulics in reply to Stephen McCurdy, 08-18-2007 11:23:35
What is the transmission oil pressure? What is the flow rate being supplied to the front pump? How old is the front pump drive coupler? Check the return to sump for every hydraulic load. Something might be bypassing back to the trans even when it's not being used. Have you added anything to this tractor and does this occur with some hydraulic equipment attached?
cannonball
08-19-2007 06:15:25
did you clean screen...
MAY GOD BLESS THE USA
Stephen McCurdy
08-19-2007 12:12:01
 Re: JD 3140 Hydrulics in reply to cannonball, 08-19-2007 06:15:25
Yep - Several times to be sure - But it has always been clean
Stephen McCurdy
08-19-2007 12:12:00
