Howdy, Yep, sounds familiar. Like Pat says, check and double check all of your passages. Every hole, big and small. If you look in the throat of your carb on the throttle plate side you should notice the following: 1 Make a note of how much wear you see around your throttle plate. If you see any wear near the bushings then put a new one in. They are still inexpensive from Deere. Use some blue locktite on the plate screws. 2 Take a look at your throttle shaft bushings and how much wear they have. If is is evident wear that you see when moving the vertical shaft from side to side, you probably need new bushings and a felt seal up top. 3 Take a look at the four holes down near the 7 o'clock position when looking in through the throttle plate side of the carb. They are around 1/32 of an inch. The two up front are for the idle portion of your carb. Are they unclogged? How about the two behind them? 4 Spin the carb around and look through the choke plate side of the carb. Every hole should be clear, round and unclogged as evident with a flashlight. Be carefull when cleaning these holes out as you can do a lot more damage to a carb than good if done improperly. 5 Take a note of any binding you may have in the linkage from the governor to carb. If you have binding of any kind take care of that to. All of this I mentioned above will have a dramatic affect on the way your 1950 B idles. Make sure you have the proper size drill bits for cleaning those holes and use only hand power, no drill. Even the right size drills can do a lot of damage to a carb if used improperly. You will know it is right when you run the tests that are on Pat Brownings web site. Remember when running those tests to make sure you have your needles (idle and load) turned our far enough when you start. Every tractor is different in this regard.
Scott
