Sorry for the slow reply. "Is there anything I can check after the local shop is done with the repairs? " Possibly. In general, I don't think the average tractor owner has any business working on his own AC internals...Heck, from what I've seen, a lot of guys who are paid to work on them need to turn in their tools until their 500 hour failure rates are well under 50%. You seem to be motivated into solving this problem, so spending a little time with you may be productive. I wouldn't buy any parts until the system is thoroughly cleaned inside and out. But since your 4240 is already in the shop, Here's what I would do when you get your tractor back, assuming you have a better than average amount of "farmer skills". {That's a good thing to have, not a put-down} 1st- I would remove the loader and the loader frames to tighten up the tractor side frame bolts. My crystal ball says this hasn't been done in years. If left loose, this causes mega $$$ of expense in your immediate future. Next- With the loader out of the way, You really can direct your attention to the problem area,- The condenser, the radiator, and everything around it. Slide the condenser halfway out to the cab door side of the tractor. Get it wet. Put on some goggles. Hold a clean white paper towel to the front side and apply a 150 psi air nozzle from the rear. The towel should only have two things on it - Water and maybe some black paint chips. Does it have any dirt on it? Then it ain't even close to being clean,- yet. Looking through it, You can see daylight through most of the fins, so it must be clean, right? Not so. Air needs to be free to "swirl" 360 degrees around each tube for efficient heat transfer. Tiny amounts of greasy dirt/chaff behind each tube attract more dirt, and very soon, your condenser is plugged yet again. Here's where you need to learn the "six - way angle" of attack for cleaning cooling components. By six-way, I am talking about cleaning your condenser with hot high pressure soap and water. Wash the core directly from the front, the back, and from 45 degrees each direction. Check you progress with the paper towel/air nozzle test. Clean? Now, remove the radiator and clean with the same method. You think there was a mess on your cement before? As a song from my day went, "You ain't seen nothin' yet". If you are having major problems keeping the front end clean, either you aren't getting it clean to begin with, and/or you have fluid leaks, and/or your 4240 isn't sealed to keep out chaff. Does the hood fit snug around the fuel tank? Do the side screens fit the hood and the tank? How about that sealing foam I asked about earlier? Does the fuel cap gasket or the fuel return line leak? That pot-metal tee that the oil cooler hoses connect to, Is that small nipple loose? Has someone welded up the steering lines and left the clamps loose/off? There can be ZERO fluid leaks in front of the radiator. A few tablespoons of oil will collect dirt which = a John Deere condenser turned into an adobe brick, which = a smoked compressor, which = $$$ out of your pocket. If your shop is oriented primarily toward truck and auto repairs, their lack of knowledge about how dirt/chaff causes chronic AC problems is probably forgivable. But if their bread and butter jobs are farm tractors, then you need to find another shop. 'Cause you are most likely dealing with people too indifferent or willfully ignorant to solve your problem. Oh, and about those update/change-over suggestions? It is true there is a slight difference in quality of various compressor rebuilders. But I learned a long time ago that the same mechanics that can kill a Frigidaire A6 can also kill a Sanden, a York, or a Nippon-Denso just as quickly. Then what do you have to show for it? I've heard all {I hope} the excuses: *The compressors are no good *R134 is no good *The specified viscosity oil, PAG 150 is no good *The expansion valves are no good * etc, etc, etc. Your tractor was designed to work for and serve you - - - NOT the other way around. Why should it needlessly consume assets better invested in your family, church, and personal hobbies?
