40 thermostat
gerard adinolfi
08-17-2007 17:29:18
just bought a 40t and got it going tonight,after running 25 minutes the water temp was hot.is there a thermostat in the cooling system?also three point didnt respond when lever was back?
thanks in advance
CPeter
08-17-2007 18:31:36
 Re: 40 thermostat in reply to gerard adinolfi, 08-17-2007 17:29:18
There is no thermostat. It is thermosyphon. When they first get goining, they sometimes heat up until the water starts to circulate. If it is boiling, then someting is wrong. If it is just hot, that may be OK. If you add antifreeze, be sure to dilute it BEFORE you put it into the radiator as it will not mix itseld in the system and that will cause it to run very hot and boil over.
