CT Popper -- Here is an extract from the JD-H Service Manual which may be of value to you. If you would like the entire section 4-6 (with figures) which deals with the PTO, write me. (PatB) ----- ----- - 4-6. Power Shaft, R/R and Overhaul -- (Figures 4-6 and 4-6-1) -- Unlike other tractors, the JD-H power shaft with bearings and gear cannot be withdrawn as a unit from the tractor by simply removing the shaft's rear bearing housing from the differential cover casting. See John Deere Model "H" Restoration Guide, 2nd Edition for expanded discussion. The Method -- Remove and reinstall power shaft, bearings and gear assembly along with the H599R rear transmission cover (Fig 4-6-1, item No. 10) as a single unit. To remove power shaft assembly, drain transmission oil from transmission/differential cavity of the main case. FOR TRACTORS with PTO and MASTER SHIELD, disconnect linkage at the bottom of the clutch lever, remove cap screws retaining H369R seat casting to main case, and lift away the seat and seat casting assembly plus clutch lever as a single unit. Remove two brake pedal springs, lower cap screw retaining master shield to rear transmission cover, remove cap screws retaining platform to main case and lift away platform and master shield as a single unit. FOR ALL TRACTORS, begin by removing ONLY the UPPER LEFT and LOWER RIGHT cap screws retaining rear cover to main case, and screw in 3/8 x 2-inch Guide Pins as replacements. Then, remove remaining cap screws and withdraw driven shaft with bearings and gear, and the rear cover as a single unit. Guide Pins are for straight-back removal. See Fig. 4-6. CAUTION! Failure to withdraw combined assembly straight back can result in sideways or up and down motion may fracture the power shaft forward bearing boss in main case. TIP -- Submit the H599R casting to engine repair to be milled to flatness to avoid leaks during reassembly. This is the only cover on series H tractors against which oil rests. The oil level is near the midpoint of the cover, with "splash" presence up to the power shaft mounting area.
