Deere 445 transaxle
Gary G
08-16-2007 17:15:29
My 1996 445 Deere has no foward but reverse works fine,any suggestions to what the problem might be? Thanks Gary
Bob
08-16-2007 18:07:51
 Re: Deere 445 transaxle in reply to Gary G, 08-16-2007 17:15:29
Have you ruled out linkage problems?
The older hydros had 2 relief valve/charge pressure check valve units, one for forward, and one for reverse, that were depressed when you activated the mechanism that allowed the tractor to be moved short distances without being running.
This newer unit, IIRC, is made somewhat like that.
Could the release lever be partially activated, or perhaps the valve used for "forward" is stuck in the released postion or defective.
Gary G
08-16-2007 20:10:29
 Re: Deere 445 transaxle in reply to Bob, 08-16-2007 18:07:51
I have checked the linkage and the release lever. I have tried moving it up and down while depressing the fwd pedal.I am thinking that the problem might be internal, however I am not familer with this type of transaxle.Thanks for the info. Additional will be appreciated
