Adjusting the Tappets on Model D
Dean Sunram
08-16-2007 17:04:40
Could someone explain the proper way of setting the tappets? I have followed the way the Operators Manual said but I set the Flywheel side first and then the right side. I come back to check the Flywheel side and it is different. When the engine is running now its seems like to much tappet noise. What am I doing wrong?
cam timing ?
08-17-2007 10:34:53
 Re: Adjusting the Tappets on Model D in reply to Dean Sunram, 08-16-2007 17:04:40
Manual should tell you if things didn't come out right setting valves to check the cam timing and how to that also. Valves won't set right with cam out of time.
