Body filler for hood patch
gurneejoe
08-16-2007 07:00:17
I read a couple of days ago about paint bubbling near the muffler on a tractor hood. I am working on a styled A and have spot weled a patch to repair a cut out around the muffler. I don't want to have problems with Bondo/heat later if this would be a problem. Has any one filled around the patch with fiberglass and had heat bubbling problems with an A? I have never done any body leading and would prefer not to experiment with this. The patch is an aftermarket one and is about 6" square. Is this far enoungh away to avoid heat issues? Thanks
Dwayne
08-16-2007 16:36:48
 Re: Body filler for hood patch in reply to gurneejoe, 08-16-2007 07:00:17
the patch repair panels are pretty nice, if yo do it right, and stitch weld it back in 1/4 inch at a time, slowly grind it back to smooth, you should need almost no filler. if you do, just use bondo, lead is too hard to work, brass is too expensive and too hard to file. unless the muffler is touching the filler, you won't have any problem. unless you have a puller the the stack glows cherry red when it runs.
gurneejoe
08-16-2007 14:31:04
I was thinking of brazing it but wasn"t sure how the sheet metal would take to the heat. I could fill it most of the way with bronze and touch it up with putty or filler maybe. The patch fits in the hole pretty good with no large gaps or anything like that. Thanks for the replies.
Joe
Goose
08-16-2007 07:53:28
I've never done this exact repair, but I'd lean toward using filler with fiberglass strands in it. The stuff gets hard as a rock and is a lot less sensative to heat than regular Bondo.
B-maniac
08-16-2007 13:01:58
 Re: Body filler for hood patch in reply to Goose, 08-16-2007 07:53:28
If done correctly you shouldn't have any body filler any closer than maybe 4". This will not be close enough to cause bubbling. Cheap paint over an improperly preped patch will bubble with the heat from the muffler right next to it sometimes. If body filler makes you nervous in this area then use a torch and apply braze rod (brass) for a filler. It grinds to shape rather easily and if cooled frequently while applying you won't have warp problems. Maybe take the hood to an expert for this part of your resto. Probably be worth the few $ he charges you in the long run. (I would take braze over lead any day)
