m quit
jon w.
08-15-2007 17:24:15
m was running rough, shut off, wouldn't start, have fire at plugs, rebuilt carb, can it be the condencer?
jon w.
08-23-2007 09:40:58
 Re: m quit in reply to jon w., 08-15-2007 17:24:15
gas was bad,,,,, ,,,thanks
Brian Bell
08-16-2007 08:24:05
Having fire at the plugs would lead me to believe that the condenser is ok. Is it possible that it jumped time? Have you verified that you have fuel getting into the carb and from carb into engine? If you flooded your engine trying to crank, you could have plugs that are weak. Might try replacing them. Also, check your point gap to be sure it hasn't closed up or gotten too wide.
jon w.
08-16-2007 10:11:28
 Re: m quit in reply to Brian Bell, 08-16-2007 08:24:05
fuel is fine, book says clockwise rotation for dist. mine turns counterclockwise, is this right ?
40 420 430
08-16-2007 21:13:18
 Re: m quit in reply to jon w., 08-16-2007 10:11:28
looking at drive end clockwise yours is okay , stay with fuel, try chockng if its pouring out the carb and still will not start then move on to the next, proper spark good bright blue
