JD 60 carburetion
M Dunlap
08-15-2007 17:11:58
i have a 1956 model 60. the engine was just bored to .125 over and the carburetor has been gone through. the tractor does not run properly untill the choke is pulled out. it seems as if it is starving for fuel. should any alterations be made to the carburetor since the bore has been increased? thanks
buickanddeere
08-16-2007 08:29:16
 Re: JD 60 carburetion in reply to M Dunlap, 08-15-2007 17:11:58
The extra airflow with just a 125 over bore is virtually nil. Airflow will change more with altitude, aircleaner condition and type of muffler. Somebody blotched something during the carb rebuild,assembly or set-up. What was the float level set at? 125 thou is only a 4.6% increase from 320.7 cu" to 335.48 cu". If it kept making .12971HP per cu" which it won't. That's only 43.51HP up from 41.6HP, less than 1.9 HP gain.
Duane Larson
08-15-2007 18:10:12
M Dunlap,
Assuming you have the idle needles open one turn each, and the fuel metering adjusting screw (in the center of the bowl nut) open 2 1/2 turns, it sounds like you have plugged idle circuits - the following previous post from the archives may help:
This provides a handy access to intermediate locations in the idle circuits. And the ball bearings blocking the drill passages are too hard to drill - I use a wire welder to build up a tab to the ball and pull the tab with a slide hammer - may take a couple of tries.-----
It sounds like some of the idle passages are still plugged. On a duplex carb like yours, it sometimes helps to check the idle circuit if you pull the two 7/16" freeze plugs located just above the bowl (one is below the fuel inlet and the second is 180 deg from the first). The exposed holes are an intermediate step for the idle fuel passages and you will see an entrance and exit passage behind the freeze plug. On each side squirt some carb cleaner in each passage and see where it comes out. Some should come out the small idle holes near the throttle plates. Squirt some cleaner down the small hole next to the nozzle plug and it should come out behind the freeze plug. This will indicate any blocked passages. If they are blocked you will have to remove the small, hard stainless steel balls to be able to ream the passages. This is not easy as they are too hard to drill. Check the archives for ways to remove them. Replacement freeze plugs are available (www.robertscarbrepair.com), but you may be able to reuse the old ones. I center-drill the plug with a #21 drill (being very careful not to let the drill go in too far and mess something up) and tap 10-32, put in a screw and pull the plug with a slide hammer. This removes the plug with little damage except for the hole. Plug the freeze plug hole with JBweld, put some sealer on the edges of the freeze plug, and tap back in with a punch around the edges.
Mike Aylward
08-16-2007 05:52:08
 Re: JD 60 carburetion in reply to Duane Larson, 08-15-2007 18:10:12
Just to add to the good advice Duane offered, these welsh plugs are readily available at your John Deere dealer. I buy them by the package all the time. A Duplex carburetor is not properly cleaned or rebuilt if these plugs are not removed. When I put them back in I will take my finger and wipe some type of sealer over them to keep them from sucking air. Mike
Mike M
08-17-2007 11:48:13
 Re: JD 60 carburetion in reply to Mike Aylward, 08-16-2007 05:52:08
I beg to differ; Not " all " of those need the welch plugs removed. I have done several of those and all were fine.But these were off tractors that had been ran and not full of water and rusted up. You can easily check to see if the passages are open by sticking the nozzle from a solvent tank into the ports and watch for flow.
Mike Aylward
08-18-2007 15:17:47
 Re: JD 60 carburetion in reply to Mike M, 08-17-2007 11:48:13
Well, Mike, I guess I will differ back. A speck of dirt the size of a speck of pepper will mess up the idle circuit. The circuit will still allow flow from an aerosol can but will not be right (with the small amount of dirt left in). It might be close, but it won't be right. It doesn't cost much to remove these plugs (I think they are about $1 each) and I will stand by my statement. I've done way too many to think otherwise. Mike
