DLTX-73 on a gas tractor
Kurt_JDB
08-15-2007 08:15:10
I am in the process of restoring my 1951 allfuel B and returning it to it's all fuel configuration. The tractor had a DLTX-107U carb on it when I bought it. The DLTX-107U was a replacement carb sold by Deere in the '70's, I think. I have located a DLTX-73 carb, which is the right carb for an all-fuel late styled B.
I have taken the carb all apart, cleaned it up, and restored the various passages to original dimensions. This carb has the "H" economizer plug and the original all-fuel nozzel. I plan to run the tractor primarily on gas.
Is there a different economizer plug I should use with this carb, and would there be any advantage to putting a gas nozzel in it?
Kurt
P Browning
08-15-2007 09:58:29
 Re: DLTX-73 on a gas tractor in reply to Kurt_JDB, 08-15-2007 08:15:10
Kurt -- a agree with Mike -- this carb is a genuine John Deere replacement, part of Agriculture-Americana!
Now, to learn what carbs were initially installed on Waterloo tractors, check in at the JD-H Restoration Site (below). Once you get there, look left and scroll down to CARB ID CHART. From the table you can look across and see answers to lots of questions, even about the economizer plug! (PatB)
Kurt_JDB
08-15-2007 10:19:47
 Re: DLTX-73 on a gas tractor in reply to P Browning, 08-15-2007 09:58:29
Pat, Mike,
Thanks for the reply. The 107U certainly is an interesting carb, and I am happy to have it. As I understand it, it was intended as a universal replacement carb for all B tractors. However it seems that it was modeled on the DLTX-34 carb, and is really a little bit undersized for a late model B, although it does certainly work fine for putting around in the neighborhood.
I have however set the goal for myself to restore the tractor back as much to the original all-fuel as I can make it, so this is why I found the DLTX-73. Took me about a year to find one. Pat, I have been to your site and looked at the chart, and the H economizer is the right one for the DLTX-73. Seems like I read somewhere though, that if you were going to run an allfuel tractor exclusively on gas, that a different economizer plug could be installed that would be more efficient. That is what I was wondering about.
Thanks again,
Kurt
Mike M
08-15-2007 10:51:20
 Re: DLTX-73 on a gas tractor in reply to Kurt_JDB, 08-15-2007 10:19:47
Don't worry about that econ. plug. just dump reg. gas in and go ! I've been doing it for years.
My B hasn't lost any power with that 107 carb. on it ? But since you actually found the right one use it instead. any of the B carbs. seem to interchange ok where you get into trouble is if you put one on from an A model.
Kurt_JDB
08-15-2007 12:28:54
 Re: DLTX-73 on a gas tractor in reply to Mike M, 08-15-2007 10:51:20
Thanks, Mike. I appreciate the insight.
Another question?
This tractor had been hacked around a lot when I bought it, and I would like to know if the glass fuel bowl and three way valve was on the large or small tank? Does anybody have a picture of this area of a late allfuel B I could take a look at?
Kurt
Mike M
08-15-2007 16:12:47
 Re: DLTX-73 on a gas tractor in reply to Kurt_JDB, 08-15-2007 12:28:54
Well I have seen and worked on alot of late A's and B's but never had an all fuel. But all of the older All fuel models I have/had the fuel bowl is on the large tank and a fitting with a strainer on it up into the small tank.
Mike M
08-15-2007 09:28:42
Why not run the 107U ? I got one on my B and it runs GREAT !!! Far better than most of the other B's I have/had.
