Help with 730 diesel
Michael Price
08-14-2007 20:15:38
Ive read about the 730 and Im confused on how to start the thing. Is there a foot pedal to release compression then crank it over and close the valve and it fires up? If anyone could tell me how to start it or anything else about this tractor I would really appreciate it.
The guy I work for just bought one of these that a good friend had before he died. Since the guy who had it died theres not anyone to explane how this tractor works.
msb
08-15-2007 18:08:51
 Do like I did. in reply to Michael Price, 08-14-2007 20:15:38
Park it on a steep hill with the brakes on. Put it in 6th gear with the clutch disengaged. Let her roll down the hill and pop the clutch.That was how I did it when I couldn't afford 4 new batteries.----- Wasn't quite 21 years old when I drove it off the dealer showroom floor.Last one the dealer sold new.Proud as a peacock, I was . Oh the memories, I could have had a 4010 if I had waited 4 months.lol,bob
dieselman
08-15-2007 18:03:31
 Re: Help with 730 diesel in reply to Michael Price, 08-14-2007 20:15:38
"Leave throttle in the "kill" position.
Pull compression release lever, and get engine cranking.
Release compression release lever, and push throttle forward. BANG...BANG...BANG... etc! "
i agree with bob...if u add the fuel before turing the diesel over u run the risk of washing down the cylinders
730virgil
08-15-2007 13:16:48
before you try starting the 730 make sure you have throttle pushed far enough ahead that fuel stuff is in.i know of a young man that didn't do that and sucked all of the oil out of air cleaner.
mjbrown
08-15-2007 13:47:56
 Re: Help with 730 diesel in reply to 730virgil, 08-15-2007 13:16:48
I'm confused. How does the throttle position affect what is happening to the oil in the air cleaner?
730virgil
08-15-2007 18:06:36
 Re: Help with 730 diesel in reply to mjbrown, 08-15-2007 13:47:56
i'm guessing because tractor wasn't getting any fuel only air had something to do with it. the guy that told me about it said kid trying to start tractor kept engine turning over for a long time until he quit trying.
Bob
08-15-2007 21:39:12
 Re: Help with 730 diesel in reply to 730virgil, 08-15-2007 18:06:36
If it "sucked all the oil out of the air cleaner", it simply didn't "make it all the way over compression", and starteed BACKWARDS, BLOWING the oil up the sir stack.
buickanddeere
08-16-2007 08:41:46
 Re: Help with 730 diesel in reply to Bob, 08-15-2007 21:39:12
I was wondering too how an engine rotating at 200rpm would draw the oil from the aircleaner. Yet running at 1250rpm it wouldn't. As for shut-down. My wife's cousins while nice guys , they are not the brightest. Nor inclined to find out the "right way" if some substitute could be made to "work". An operator's manual would not be used for reading purposes. Anyways they stopped the engine by either stalling it in 6th. Or pulling the decompression and watching the grey mist of raw diesel blow out the stack. They looked absolutly puzzled when I pulled the dash knob and brought the throttle back to stop position. Then they asked if that was the correct way to shut the engine down because they usually "pulled this lever over here". They had no idea the decompression lever was decompression and it was to be used.During starter or cranking engine engagement, until oil pressure and before any fuel delivery.
Chris in MD
08-15-2007 10:55:26
That...my friend, is why they make OPERATOR'S MANUALS.
If you're going to keep the tractor, the operator's and service manuals are worth every single penny. No and's, if's, or but's about it.
Ferd
08-15-2007 08:24:21
You may also need to know how to stop it. There's a "button" on the lower right side of the dash that, when pulled out, allows the throttle to be pulled all the way back to shut off the fuel supply. So starting it, push the decompression release foot petal down, hit the starter and get it rolling (might even check for oil pressure), drop the decompression foot petal and as soon as you move the throttle open (allowing fuel to flow) it should start right up.
mjbrown
08-15-2007 04:51:17
The foot pedal in front of your left toe holds the exhaust valves open a smidgen releiving compression. You hold it down and push the start button and get the flywheel spinning good so it has enough momentum to kick it over on full comperssion when you let the pedal up.
carl bryant
08-14-2007 20:20:28
step on the pedal and then push the start button than move your foot it well fire up quick
Bob
08-14-2007 20:20:05
