830 3 cyl. injector line leak
Michael Sheik
08-14-2007 11:32:49
JD mechanic and the local tractor mechanic says it could be either the line or injector connection surface is damaged. Said to try the line first and if that didn't stop it, put in the reman. injector. I am going to do the line myself but if the injector needs replaced, my buddy, the local tractor mechanic will do that.
I am thinking one should screw the line nut onto injector fairly snug prior to putting pump connection on. That would keep the injector connection surface as straight as possible form the start. Right?
G/MAN
08-14-2007 13:45:12
 Re: 830 3 cyl. injector line leak in reply to Michael Sheik, 08-14-2007 11:32:49
If you're dealing with the "banjo" fittings with the sealing washers, try the copper washers if you can't get the steel ones to seal. DON'T get carried away with tightening them, though. The copper seals easier but they don't seem to last as long, and overtightening EITHER type can result in a broken off fitting bolt. You might remove the line and inspect the sealing surface on the line and dress it with fine emery cloth if necessary, then flush it well before installation. Definitely make sure it's not the line before installing a different injector, and if the injectors have many hours on them at all and you have to replace one, consider pulling them all and testing them. It's generally best to replace injectors in a full set, unless it's a new or recently replaced one that needs replaced. They all wear out over time.
