70 PS
Gwiz
08-14-2007 07:30:18
Is it possible for powersteering fluid to migrate into the engine compartment on a 70gas???I have lost the fluid with no external leaks and my crank case is over full.Are the seals on the PS pump leaking internally???
GWIZ
08-14-2007 10:57:46
 Re: 70 PS in reply to Gwiz, 08-14-2007 07:30:18
Thanks guys for the replies back. That's what I was afraid was at fault.I will be sure to inspect the shaft for any obvious problems.
Blksmok
08-14-2007 08:55:37
Gwiz...yes, the p/s fluid will leak past the rear pump seal, down the fanshaft tube, into the governor housing and into the crankcase. Don't be surprised if the main shaft in the p/s pump is worn, pitted and grooved. May need to replace that also.
Mike M
08-14-2007 07:32:22
Yes! and Yes !
