JD 2150 Head and rod bolt torque
bucyrus
08-14-2007 07:24:42
Can anyone tell me the head and rod bearing torque specifications ona John Deere 2150 4cyl. diesel
Thanks for any help
brian
buickanddeere
08-15-2007 08:00:19
 Re: JD 2150 Head and rod bolt torque in reply to bucyrus, 08-14-2007 07:24:42
If asking about the old original bolts? The answer is zero lb ft. Do you feel lucky enough to re-use pre-stretched & aged fasteners in critical applications? How did you "rebuild" the engine without knowing proper bearing clearance, sleeve projection, deck clearance, valve height etc? Did you grind the original valves & seats then re-assemble?
720 in pa
08-14-2007 08:07:27
2150 with 4 cyl? dont know about that,but rod bolt torque should be 75 ft. lbs. and head bolts should be 110 ft. lbs.
bucyrus
08-14-2007 14:35:36
 Re: JD 2150 Head and rod bolt torque in reply to 720 in pa, 08-14-2007 08:07:27
Thanks for the info
It is a 3 cyl. the 4 was a typo on my part
