2555 Charging problem
Tim Snellgrove
08-14-2007 05:41:41
I'm having a problem with the battery charging on my 2555. Open station, no cab. I've tested the batteries, cleaned the terminals etc. Output of the alternator never seems to climb above nominal battery voltage. I put in a new alternator thinking that must be the problem but no joy. The alternator has an internal regulator as best as I can tell. There is only one wire other than the main charging wire. The one crappy diagram that is in the IT&T book shows a diode between the instrument panel and the alternator and this smaller wire. I read the same voltage on the smaller wire as the big wire. Anybody out there have any experience or ideas?
Thanks
Tim S.
buickanddeere
08-15-2007 08:04:15
 Re: 2555 Charging problem in reply to Tim Snellgrove, 08-14-2007 05:41:41
There is a wire coming from those Bosch units to operate the tach. Is your Bosch a JD rebuild or a generic rebuild and not equipped with enough connection points? Those IT manuals are best used to hold doors open or to wrap around fragile items so the vice doesn't marr them.
Tim Snellgrove
08-15-2007 13:04:55
 Re: 2555 Charging problem in reply to buickanddeere, 08-15-2007 08:04:15
Buick It is a generic rebuild, but looks exactly like the one I took off. Same connection points and all. I'm not sure the original one was bad now that they both exhibit the same symptoms. The belt is not slipping and I see no change in voltage when I rev the motor up or not.
buickanddeere
08-16-2007 08:50:49
 Re: 2555 Charging problem in reply to Tim Snellgrove, 08-15-2007 13:04:55
Is there something open in the wiring harness between the alternator & the battery? Try a direct run with another cable.
Tim snellgrove
08-14-2007 07:50:01
Thanks for the reply. It is the Bosch alternator.
Bob M
08-14-2007 08:46:31
 Re: 2555 Charging problem in reply to Tim snellgrove, 08-14-2007 07:50:01
OK Tim. I don't have much experience with the Bosch alternator. However the one Bosch I do have has only two wires to it:
The B+ post goes to the heavy wire to the battery +. The D+ terminal goes to the switched side of the key switch thru a warning light and 330 ohm resistor connected in parallel. (The remaining terminals are not used.)
If your's is the same I guess I'd begin by taking voltage reading to ground at the alternator as follows at the B+ terminal. It should show battery voltage at all times.
Next remove the connector from the alternator D+ terminal. It should show 0 volts with the ignition off and approx 12 volts with the ignition on.
If you don't get the above readings you'll need to find and correct a wiring problem. Otherwise suspect the alternator or it's onboard regulator is bad.
Bob M
08-14-2007 07:13:50
Tim - Assuming the alternator on your 2555 is a Delco, problem may be it's missing the "voltage sense" wire.
There should be 2 wires running to the aux connector plug at the back of the alternator:
The #1 is the control terminal. It should connect to the switched side of the key switch thru either a diode/resistor, or to the alternator warning light if the tractor has one.
#2 is the voltage sense terminal. It connect directly to the larger BAT terminal at the rear of the alternator.
If the alternator is working properly you should read 14.0 - 14.5 volts across the battery with the engine running!
