2555 JD hyd problem
Gary Blackwell
08-13-2007 17:59:05
A friend of mine has a 2555 and is having a hyd problem. He said it don't have the lift all the time it should.Has a new filter,oil level is full. workes better cold than hot. Sometimes it rattles the lines like it has air in it. He would like to know where to start looking. I can't help him my newest tractor is a 1960.
Thanks Gary
Tx Jim
08-16-2007 04:09:30
 Re: 2555 JD hyd problem in reply to Machinery-Man, 08-13-2007 17:59:05
Gary does tractor have indepenent pto and hyd hi-lo? If so either/or both could have a cracked line causing problem. On SCV you could plug off supply line to SCV and run to see if problem went away with out R&R SCV. Tx Jim
Gary Blackwell
08-16-2007 02:59:31
 Re: 2555 JD hyd problem in reply to Gary Blackwell, 08-13-2007 17:59:05
Thank you very much
Gary
Lonnie J Wallace
08-13-2007 22:02:08
there is all kinds of things that can cause your problems. lets start with the PTO, does the problem start with the pto on or off? how about the 2 speed does the problem show up with the 2 speed when in high or low? Does the rock shaft start droping as soon and the engin is shut off? When the problen comes on see where the lift arms up or down, What i am looking for is a leak some where in the syestem that is looseing the oil before it gets the main hydraulic pump. See if the remote valves are hot after the tractor has been run, and what is the tractor being used for when hydraulics go out?
lonzl
08-15-2007 19:05:33
 Re: 2555 JD hyd problem in reply to Lonnie J Wallace, 08-13-2007 22:02:08
Hook a 5000psi pressure gage in each remote out let and push or pull the control lever in cab and when pressure is up put the lever in neutral, the pressure should stay there or it could drop 200 or 300 lbs but not keep on draping. Next test,Shut off engine and work the levers to release pressure, plug the gage back in outlets and start tractor, the gage should not pressurize( 1 or2 minutes ) while levers are in neutral. What is happing is that the remote valves are leaking inside and the main hyd pump is trying to keep the pressure built up and is useing all the oil and there is none left for other things. It's not too big a job to remove the valves and have them rebuilt, I take the wheel off and have more room, good luck
Gary Blackwell
08-14-2007 06:18:50
More info. Problem starts with pto on. It shows up in high speed. The rock shaft stays up when the tractor is shut off. The lift arms are down when it acts up. The remote valves are real hot and the tractor is used to run a brush hog.
Thanks for the reply and hope this helps some more.
Gary
