'67 4020 audible alarm?
wsimpson
08-13-2007 12:21:45
About to purchase. After ignition, audible tone. All gauges show fine and no idiot lights. Any ideas? Thanks...
Gerald J.
08-15-2007 12:00:42
 Re: '67 4020 audible alarm? in reply to wsimpson, 08-13-2007 12:21:45
Some 4020 have an alarm when the vacuum through the air filter indicates its plugged. Its a vacuum operated whistle on the pipe between the air filter and the carburetor.
Mine doesn't have it.
Gerald J.
msb
08-13-2007 21:10:00
Tractor has no alarm. Voltage regulator? Sticking starter solenoid?
Gerald J.
08-13-2007 16:19:45
Check the crankcase ventilation pump.
Gerald J.
Chris in MD
08-13-2007 12:43:51
They have a horn, apparently the horn button is stuck. (on the lower dash left side)
Are you even talking about a horn? (horn = alarm?)
wsimpson
08-13-2007 12:23:12
Not sure if it makes a difference but this is gas-powered. Thanks...
