830 3 cyl injector line leaking
Michael Sheik
08-12-2007 19:31:34
Leaking a drip about every minute at the junction of the line nut and injector. Doesn't seem to cause any performance issues, just a mess on the engine. I snugged up the nut a little and didn't stop it. I am assuming the flare connection must be on there a little crooked. I'm not doing anything else until I ask you all what you suggest.
msb
08-13-2007 06:40:37
 Re: 830 3 cyl injector line leaking in reply to Michael Sheik, 08-12-2007 19:31:34
To add to what Bob has told you, rinse off any connections in John Deere paint thinner and blow dry with air. Diesel fuel attracts dust and dirt from the atmosphere and can cause leaks. The other advice is to be sure when tightening the fittings that you don't put a stress on the line . Stressed lines and fittings will loosen up from the normal vibration of the tractor.Try to tighten them down exactly as in the shape they are before putting a wrench on them.
Michael Sheik
08-13-2007 04:37:21
If I pull the line to clean and re-install, will I have any trouble with air. I would assume one would have to leave that nut a little loose at the injector and spin over to get the air out. Am I right?
Bob
08-13-2007 10:23:17
 Re: 830 3 cyl injector line leaking in reply to Michael Sheik, 08-13-2007 04:37:21
If you just disconnect it at the injector, it shouldn't be necessary to bleed the line, but, of course, leaving the fitting a bit loose, cranking then engine, then tightening the fitting certainly can't hurt.
Bob
08-12-2007 19:42:52
It's NOT uncommon for injector lines to crack right next to the fittings. Is it leaking on the injector side of the nut, or the line side?
Which line is it... I'll surf over to jdparts and see how much a new one is.
Michael Sheik
08-12-2007 19:45:30
 Re: 830 3 cyl injector line leaking in reply to Bob, 08-12-2007 19:42:52
It is leaking on the injector side and is the middle one.
Bob
08-12-2007 22:00:58
 Re: 830 3 cyl injector line leaking in reply to Michael Sheik, 08-12-2007 19:45:30
The line is less than $30.00, if that is the part that's leaking, the injector is less than $85.00 from Deere, and probably cheaper at a local injection shop, if it's line turns out to be what's cracked.
You can try disconnecting the fittings, blowing them clean with compressed air, then reassembling, to see if that stops the leak before replacing any parts.
