70 with oil to center main but it is a 70 part no.
Mike w J
08-12-2007 19:11:36
My son has a 70 that we are taking apart tach shows 3800 hours has standard pistons. The rod bearings bearings look like new cylinders are wore quite a bit had 3 broken top rings. It has a cracked head he is going to put 720 pistons /head /injectors/ pumps in it. Could 3800 hours be correct or is it 13800 ? The center main has a oil line feed to it did someone drill and tap this or is it aftermarket? It does have a 70 part no. on it F1914R .how hard is it to find over size piston in good shape ?
Mike M
08-13-2007 05:20:31
 Re: 70 with oil to center main but it is a 70 part no. in reply to Mike w J, 08-12-2007 19:11:36
hours are closer to the 13800 figure I'd bet.
buickanddeere
08-12-2007 20:27:27
720 & 730 heads are more crack resistant along with better flowing intake ports. Getting the cam & followers re-ground would be good insurance. The flywheel/crank splines and the cam idler gear/bearing must be closely inspected.
WeirdDeere
08-12-2007 20:00:00
I remember seeing a JD "Field Service Bulletin" that showed how to make/install a separate oil feed line to the center main bearing on a 70D. I'd bet that's what happened to yours.
There are sources for new 730 diesel pistons that would work for your 70, and I'm sure there are .045 over available too.
Brandon
