JD 60 pto problems
Randy S
08-12-2007 13:59:45
I would like a second opinion on whats going on with my pto. Was bush hogging Saturday and noticed oil dripping out from around the pto shaft. At first i thought, another seal gone, but upon checking the oil level in the pto i had about a quart run out of it when i removed the plug, the oil was under pressure and HOT when i removed the plug. Yep got burned a bit, wasnt a happy camper at the moment. I thought maybe it was comming from the rear end so i checked the oil level there and its ok, up to snuff. I replaced the plugs and finished hogging about another half acre. This am i went back out and rechecked after it had cooled and over full again with differential still up to snuff. Can someone give me a clue as to whats going on here. And oh yes the first opinion i got is mine, all i know to do is start removing the pto to see if i can find anything and thats not a idea i like (exploratory surgery).
Randy S
08-12-2007 20:24:10
 Re: JD 60 pto problems in reply to Randy S, 08-12-2007 13:59:45
Thanks a bunch. Thats exactly what i was thinking. I have had it down several years ago and replaced that seal, i guess ill just have to do it again.
2cylinderlp
08-12-2007 15:24:47
OK, my opinion would be that it sounds like you are getting gear oil into the PTO. Even though your tranny gear oil level dosn't seem to have dropped, that would be the most likely place for the PTO to gain fluid from. The tranny holds quite a bit and loss of a quart or two might be hard to see. The clutches in the PTO don't like gear oil and can be damaged by it. If it were mine I would take it apart and replace the seal that is in the power shaft pump. I think it would be good do this if for no other reason than just to protect the pto clutches from future damage. But obviously in this case you have other reasons. The clutches are expensive to replace. To get at the seal you have to take the rear housing with the rock shafts off. You probably want to disassemble the clutch pack and inspect it too. I don't think you can get the clutch pack out without taking the rear housing off. It is locked in by the gear teath for the the pto pump which is on the other side of the rear housing. A manual would be very helpful for this job.
Mike M
08-12-2007 15:21:55
Very common for the tranny oil to get into the pto via. the oil seals up on the insides of the pto units pump. You may not notice the tranny drop much as it won't take much to over fill the pto. Plus the engine oil can leak into the tranny oil via. the RH crankshaft seal. These old 2 cyls. are masters at mixing fluids. Probabaly the reason the newer stuff went to one oil for all.
