35 B oil leaking past main bearing bolts
Russell S.
08-12-2007 12:36:28
I just got my 1935 John Deere B running for the first time in about 30 years. I did a complete rebuild on the tractor. Now I'm trying to work out the kinks. On the L.H. main bearing bolts, oil is running out from behind the nut. Can anybody give me some advice or info to help me stop this leak? Also, could this be the cause of low oil pressre? When idling,the gauge reads just over the L mark. I thank you for your help on this.
Mike M
08-12-2007 17:48:36
 Re: 35 B oil leaking past main bearing bolts in reply to Russell S., 08-12-2007 12:36:28
Did you try adjusting up the oil pressure ? Up under the fanshaft on the front of the gov. housing there is a cap nut remove it and the adjustment is under there.
I'd put some sealer under the nuts.
