hydraulic problem?
JohnMB
08-12-2007 12:24:25
Have 2020 with hyd oil getting into crankcase.
Has front mount pump for all hyd stuff
Where can this be getting in?
Is there a connection between steering valve and c"case?
Do not have manual yet.
Thanks
Charles Smith
11-05-2007 20:47:11
 Re: hydraulic problem? in reply to JohnMB, 08-12-2007 12:24:25
Hope you have discovered by now the small hydraulic pump on the front engine cover. If not, pull the radiator and you will find it on the front cover of the engine. This is the only place on the tractor that hydraulic fluid can enter the crankcase.. You have a blown seal on the drive gear.
good luck
Tx Jim
08-13-2007 04:00:58
 Re: hydraulic problem? in reply to Jim Fisher, 08-12-2007 12:24:25
2020's had a power steering pump mounted on front of engine that may be leaking. Tx Jim
JohnMB
08-13-2007 08:23:39
 Re: hydraulic problem? in reply to Tx Jim, 08-13-2007 04:00:58
Thanks guys.
This tractor does not have the separate power steering pump on the front of the engine. Power steering oil comes from the common pump driven by the front of the engine crank and through a priority valve.
Is there any way oil could be leaking from the steering control valve into the engine?
MSM
08-12-2007 13:00:31
Are you sure it is hydraulic oil? The fuel pump(gas or diesel engine) or injection pump can leak fuel into the crankcase.
JohnMB
08-12-2007 15:00:35
 Re: hydraulic problem? in reply to MSM, 08-12-2007 13:00:31
Yes I believe it is oil rather than fuel.
No odour, not thin.
Level in trans. goes down, engine goes up.
