JD 2840 INJECTOR PUMP
SHORTORDER
08-12-2007 08:39:17
I have a JD2840 that runs fine. The problem is went I turn it off after several hours of operation it will not start. If I let it set for several hours until it cools down, it will start with no problem. Is this a indication that the injector pump is starting to fail or is there another problem area. I have a good clean fuel filter, it is not a lack of fuel because of the filter. Thanks for any input to the problem.
shortorder
Tx Jim
08-13-2007 03:50:41
 Re: JD 2840 INJECTOR PUMP in reply to Jim Fisher, 08-12-2007 08:39:17
shortorder does it spin over as fast when hot as cool? Brandnew 2840's didn't crank great when they were hot. Have your tried moving steering wheel back and forth while cranking to relieve hyd pressure? If that helps a hyd pump destroking screw is needed. They can be bought from JD in manual or electric. Tx Jim
buickanddeere
08-13-2007 05:23:00
 Re: JD 2840 INJECTOR PUMP in reply to Tx Jim, 08-13-2007 03:50:41
The factory 3KW Bosch stater is so so. There is a direct bolt on 4KW Bosch used on Dubuque six cylinders such as the 414. The voltage needs to be properly measured at the starter when cranking. Those dual 12V systems often turn into a one battery system. The other battery will go along for the ride and do zero if the terminals are the least bit dirty. The chassis (-) return cable bolting onto the firewall sheet metal wasn't a good idea. There needs to be a HD cable run down and fastened under one of the starter mounting bolts.
SHORTORDER
08-13-2007 04:18:16
(Tx Jim) When the engine is hot it turns over very slowly, turning the steering wheel back and forth has no effect. In fact it turns so slow it would make you think there is a battery problem. When it is cold down the engine and battery give no indication of a problem. (msb)I have checked the electrical connection and do not see a problem. If there is a metering valve sticking, is there away to futher indentify the problem? Well it hurt the tractor to keep runing it until it dies and then fix the problem?
shortorder
msb
08-12-2007 10:35:28
 Re: JD 2840 INJECTOR PUMP in reply to SHORTORDER, 08-12-2007 08:39:17
Could be a bad or corroded electrical connection or a sticking metering valve inside the injection pump.
