4020 diesel in crankcase again
Toby Woodmore
08-11-2007 15:56:14
Cranked 4020 to move it around in shed yesterday and looked like a broken water main with diesl pouring out of crankcase. new rebuilt injector pump and transfer pump out of another 4020 that was not leaking. What is the best way to tell which one is leaking and get on with this. This is my disc mower tractor and want to use it if it ever rains.
Toby
msb
08-11-2007 17:40:44
 Re: 4020 diesel in crankcase again in reply to Toby Woodmore, 08-11-2007 15:56:14
I would pull the transfer pump off and put a small amount of air pressure in the inlet side while plugging off the outlet with a finger unless you know for sure the injection pump was not run on a test stand. That is one of the reasons for using a test stand. I am guessing it was not tested and the upper cup seal was inverted when the pump shaft was installed.Its easily done if the bushing is grooved like so many shaft bushings are.
Mike M
08-12-2007 15:48:01
 Re: 4020 diesel in crankcase again in reply to msb, 08-11-2007 17:40:44
Couldn't you also test that inj. pump if off the same way with a SMALL amount of air pressure in the inlet or return ?
msb
08-12-2007 19:13:25
 Re: 4020 diesel in crankcase again in reply to Mike M, 08-12-2007 15:48:01
Might as wll pull the shaft if the pump was off the engine and have a look at the cup seals.Also carefully inspect the cup seals for tears on the inside diamater of the seal. Inverting (turning wrong side out)the seals will occasionally tear them and it will about always make microscopic tears the naked eye can barely see. Tears, which only to let go later.
