46 b issues cont.
patsdeere
08-11-2007 11:37:21
I have some issues I was hoping somebody would have the magic cure to. 1. I am trying to get the hubs off my axles and have heated them with the torch (until they are almost orange), have a 8 ton jack on it and yet to see any movement. I have soaked them for the last couple of weeks. Any more suggestions?
2. I am trying to get the friction plates on my fan to let go of the shaft that they have decided to stick to. I have tried clamping them against the pulley (bad things happened, like a cracked pulley), I have tried heating it, and smacking it, but no luck. Any other ways other than maybe a press to get the plates to let go? Also, if the crack is a hairline fracture, would a simple weld job suffice to keep it in 1 piece?
Chris in MD
08-12-2007 18:47:29
 Re: 46 b issues cont. in reply to patsdeere, 08-11-2007 11:37:21
I like to plow with a frozen wheel. When it comes loose, you'll know, trust me.
Mike M
08-12-2007 17:57:31
I wouldn't weld that fan pulley as a used one should be easy to find.
May as well just use a cutoff wheel and get those alum fan drive discs off.
The worst hubs I had to remove I had to affix a large gear puller to them so I could pull straight,then apply heat,then cool the axle with water. Those were very ! tough. Most of them will go with a puller after a long time soaking with penetrant.
Kurt_JDB
08-12-2007 13:04:45
Patsdeere,
With regards to the fan clutches, mine could not be moved no matter what I did. They are made of some kind of potmetal, or maybe aluminum. Anyway they are available from Deere (or were recently)for a reasonable price, so I cut mine off carefully, and replaced them. The old ones were no good anyway.
Kurt
Dave Pearson
08-12-2007 08:03:10
I've had pretty good luck at freeing them by loosening them and then driving the tractor in tight figure 8's. Do keep an eye on them so as not walk the wheel off the axle when they free up.
