3155 JD
flying belgian
08-11-2007 15:25:33
Local Case dealer has a JD 3155 with loader for sale FWA. Needs a lot of cosmetic work but apears to be machanically sound. I know nothing about these tractors. Good, bad or ugly? It has 18-4-38 rubber. Would it go down the road pretty fast as I would be replacing my 706 IH. Pulling wagons down the road. It has cab and non-working ac. 9000 hours. what would it be worth?
buickanddeere
08-11-2007 08:10:00
 Re: 3155 JD in reply to flying belgian, 08-11-2007 15:25:33
Excellent tractor generaly. As usual if the previous owner was the type who could break an anvil with a runner hammer, run away. Check the anti-freeze for corrosion inhibiter. And the trans screen & filter for friction material or metal. Dry clutch but unless used by an animal doing loader work. They are lots durable.
sam from WA
08-11-2007 07:13:03
3155s are a hell of a tractor. we used to have one and it got to be pretty beat up before we traded it on a 2955. it is a bit of a pain to run it for loader work with the cab on it, but we got used to it. its not as bad as our 4450 that has a loader on it. the 3155 will go faster than your 706 and it will do a lot more work before it lugs down. i'd say its probably worth 10,000 to 15,000. we bought ours new and i can't remember what we sold it for. it had bigger porblems than the one you are lookin at.i want to say that the front axle had a big crack in it from freezing because there was a seal or something that was out and let water in.
9000 hours or 2000, i'd say buy it. you can't wear them out unless you do something to it or overtax it.
