G Head job now leaking water out the exhaust
Ben.So.Tex.
08-11-2007 06:42:45
I took the head off my G and gave it a vavle job also and resurface it. No crack in the head. When I crank the tractor after it has set for a day or so water will come out the exhaust and spray the roof in the shed and some will fall on to the tractor. Where could this water be coming from? It was not doing this before the vavle job. Ben
Earl-IL
08-12-2007 10:01:20
 Re: G Head job now leaking water out the exhaust in reply to Ben.So.Tex., 08-11-2007 06:42:45
Ben, Would there be a problem in the manifold studs? Did you change anything there?I had some problems with the late "G" head gasket in the past but they wanted to seep outside. Deere had 2 vendors & the one had a quality problem. You might try Olson in Oregon if you think it is a gasket problem.He might have some Victor or Felpro gaskets. But I had some manifold studs leak into the ex. port. But trueing the head & true the manifold and using tight fitting studs not cap screws solved that problem.
MJN in OH
08-11-2007 16:29:07
Ben
I had the same problem on a 60 with a 6-3 powerblock. I hate to say it but one of the o-rings in the block is probably leaking. I used the head gasket as a template and cut a blank out of plywood and used RTV or any sealant and added water to the block and wait and see what happens. In a little bit of time I had water in the number 1 cylinder. I also blanked off the upperwater pipe opening and and added about 10 psi of air and then you could for sure tell what was going on. I have used this same method on heads and it works good also. They say there is not much you can do with your block once this happens but this winter I am going try to get the sleeves out of that block without destroying them, and put new O-rings on. Hopefully it works that easy.
Goodluck
P Browning
08-11-2007 10:22:36
Ben -- I think I would wait a day and try it again -- could just be a fluke. (PatB)
Ben.So.Tex
08-11-2007 15:04:25
 Re: G Head job now leaking water out the exhaust in reply to P Browning, 08-11-2007 10:22:36
Pat I did this head job about 6 months ago, so I don"t think it a fluke.
I was hoping that it would of quit by now.
I retorque the head after I installed it with the engine warm. The only think I didnot do was install any gasket glue. I have never used it(glue) on my other tractors.
JD@Antique Acres
08-11-2007 09:31:16
How were the guide tubes? Thats what I would check first.
Ben.So.Tex.
08-11-2007 09:59:05
 Re: G Head job now leaking water out the exhaust in reply to JD@Antique Acres, 08-11-2007 09:31:16
Thanks
This G has a power block (1949), If the tube had a hole it would leak water into the oil, or am I wrong? It only spray a couple of table spoon or more when I start it up, and it is not condensation build up.
730-LP
08-11-2007 09:13:34
 Re: G Head job now leaking water out the exhaust in reply to Ben.So.Tex., 08-11-2007 09:59:05
G power blocks are REAL WEAK where the center head bolt goes and will break if torque to tight or the bolt is screwed in to far.did you use the right head gasket,there are 2 different ones?Did head have alot of junk inside.I bought one off of a running tractor that didn't leak but when it was cleaned up it did.
Ben.So.Tex
08-12-2007 07:19:51
 Re: G Head job now leaking water out the exhaust in reply to 730-LP, 08-11-2007 09:13:34
Head did not have alot of junk in it, New gasket matched the old one, I have not pulled the plugs before cranking because the tractor is not fouling out when it starts, just throws some water when it cranks up. This G is use for play not farming.
Will P
08-11-2007 10:50:12
If you have a styled head, there is no pushrod tubes. Unstyled head, I have no idea if it has tubes or not.
Will
