Fixed the 310E backhoe that wouldn't move FWD
TV Casualty
08-10-2007 20:55:46
Re: 310e 4x4 backhoe will not move forward (rev OK)
Thanks to Ken for asking me if I ever fixed the problem - figured I'd post my solution here as well... Forgive me, but I fixed this several months ago, and would have to go look at the machine again to verify the complete accuracy of my recollection:
I solved the problem, but I'm not sure how to describe what I did - though I'll try.
There is (as best I recall) a large wiring harness that runs from the dash (at the steering wheel - not the lights, starter switch, etc. panel) to the transmission. This harness terminates in a fat military-style connector that feels like a bayonet type. You turn and pull at the same time to remove it.
To my recollection, there are maybe 20-25 pins total. I originally felt that this connector was the link between my FNR lever and the tranny, so I wanted to see if it was damaged. Best I can remember, it was a bit dirty, and maybe even slighty corroded. I first soaked it with WD-40, then instantly remembered that it acts as an insulator, and of course, the whole machine shut down. I then sprayed the connector with contact cleaner (as you would use for electronic parts). Once the contact cleaner displaced the WD-40, I was instantly back in action. That is ALL that I did after unsuccessfully trying every other thing I could with no success. I still haven't found any conclusive evidence that the connector is what I thought it is, but it doesn't matter - it seems to have resolved my problem.
Russ
