Is there a way to increase the deck speed on a JD 140??
Chris G
08-10-2007 20:13:48
I have a 78 JD 140 and am looking into way to increase the deck speed by about 500 to 1000 rpm. Here are the ideas I have thought about so far:
1) Replacing the deck pulleys from another deck
2) Replacing the engine shaft pulley with another one
3) Replacing the whole deck (bigger than the current 48", say 52" or 54", anything bigger is overkill) that has bigger pulleys and a better wheel setup
However, I am unsure what would fit properly and allow for a common belt/pulley of some form or another.
Let me know and thanks!!!!!
Chris
buickanddeere
08-11-2007 06:58:28
 Re: Is there a way to increase the deck speed on a JD 140?? in reply to Chris G, 08-10-2007 20:13:48
As previously stated, you are in over 1/2 the price of a brand new LA140. As good as the 140 is, you will only use it for parades after using the LA140. Before doing anything else. Get a tach and make certain the engine is running 3600-3650rpm when cutting. Replacing the worn engine pulley with a one new will pickup a couple of deck rpms.
Chris G
08-11-2007 09:19:57
 Re: Is there a way to increase the deck speed on a JD 140?? in reply to buickanddeere, 08-11-2007 06:58:28
Thank you for the info. I will have to check the RPM speed with a tach soon as well as checking the main pulley setups. I think, between other projects, I may just rebuild/retire the old girl. It"s a heck of a mower and I"d defiantely miss it. The sad thing is, I can trade it for two or three White"s (yeah I know they are rebadged MTD"s) and MAYBE even an old tractor (unknown who"s, about the same overall size of an Ford 8N, but without the non-direct PTO issues) that uses a belly pan.
Anyway, thanks again for the info.
Chris
wilamayb
08-10-2007 21:44:19
I replaced the deck on my 140 with a newer style deck offered by Deere to fit these old machines. It does have a higher blade tip speed and seems to have a much better vacuum. It is a much better built deck with a wheel on each corder and greasable spindles. The price was not for the faint of heart. I think I paid over $700.00 and I bought it from the dealer I worked for at cost. The deck did require a conversion kit and special belt sold by the parts department. The deck does leave the grass slightly taller between the blades, but not nearly as bad as the old deck.
I can help you with the part numbers, but I'll have to do some deep looking to get you a price and whole goods number for the deck if you are interested. It does mow much better and does not does not scalp as my old deck did. I put the deck on mine just because it was a family machine that I hated to junk just because the deck was shot. It may not be a good investment for you since you can buy a new X320 for only a few dollars more than you can spend on your old 140 and have a better mowing machine, but wont be nearly as fun.
Chris G
08-11-2007 09:19:39
 Re: Is there a way to increase the deck speed on a JD 140?? in reply to wilamayb, 08-10-2007 21:44:19
Thanks for the info. Though it is out of my price range, I am curious on what the part numbers for the deck/belt/extra parts. The biggest issue I have with my deck are the pricey wheels. I have wasted quite a few pair and would LOVE to be able to go with ball shaped ones that pivot more. I DO have another set of great wheels, but am having issues finding the right bushings to put it all together. Thanks again!
Chris
