855 tractor and biodiesel
N.G. Orfanakis
08-10-2007 18:11:40
I would be interested to know if there are any conversion kits being made for the 855 so that I can use biodiesel in addition to regular diesel?
Mike Aylward
08-11-2007 08:31:05
 Re: 855 tractor and biodiesel in reply to N.G. Orfanakis, 08-10-2007 18:11:40
N.G., are you talking "home brew" biodiesel, or one of the commercially available blends such as B2, B5, B20, etc.? The commercially available blends will perform just fine in your tractor but the higher concentrations will require a heater or an additive in colder weather. Many "home brews" do not filter out a lot of the solids and come with their own problems. Biodiesel is a good product with much better lubricity than many over the counter diesel fuels but they require some changes in mindset. In very cold weather you will likely be better served with straight diesel fuel. Also, due to the fact that biodiesel is an organic product it is possible that you will need additional anti-bacterial products in your fuel supply. Hope this helps. Mike
buickanddeere
08-11-2007 07:04:49
ebay has bio-diesel everything. If your veggie oil is from anywhere other than your local name brand fuel dealer. The bio has to be well filtered. The fuel should be pre-heated before entering the injection pump. The engine should be running 195F minimum and 220F better. The engine should also be used at full power instead of doing putting around jobs. Otherwise you will be scrapping carbon,purchasing new head gaskets and new head bolts about every other oil change.
