I think you hit the two things that can cause the problems. It's gotta be the cylinders or the valves so long as you dont have any external leaks. A good way to check is to raise the loader and unplug the hoses from the back of the tractor if you are running the loader from your SCV's. If you have your loader plumbed into a joystick then you'll have to be a little more resourceful and buy some plugs or caps to plug your cylinders while the loader is raised. We use a chain fall for this, but you'll have to use a pole under the bucket or hold it up with another loader... etc.... while you cap your cylinders. After youve got your loader isolated from your tractor it should be easy to see which one is causing you the probs. Those jerky lines upon startup are from, as the other gentleman said an inadequate delivery of hydraulic fluid to the main pump. This jerking is called cavitation which is just as the name suggests. There is a cavity in the line that is not filled with pressureized oil. This occurs everytime you see the line jump up and down. The line jumps everytime a piston in your pump makes a stroke which is about 8 times engine speed since there are 8 pistons in your pump. This can be fixed by supplying enough oil to your main pump at startup. It may be a checkvalve?? If your system has an airleak anywhere on the supply side the oil will drain back to sump while the tractor sits turned off. Sometimes if this isnt too bad it can wait until you have the tractor split for some other reason to see the location of the leak. The best of luck with that loader! Glad to see another TN resident here. I'm a middle Tennessean from the big town of Centerville. Where is home for you?
