Info on John Deere 140
Ron Rohner
08-09-2007 21:03:20
I just acquired an old John Deere 140. I am trying to find out its exact age and horsepower.
I have the following info on the tractor.
serial number: 038533 M
type: 10585
Kohler engine number: 3156256
I need the above info so I can purchase the proper parts and repair manuals..any help would
be appreciated...thanks...Ron
Bob
08-10-2007 01:05:29
 Re: Info on John Deere 140 in reply to Ron Rohner, 08-09-2007 21:03:20
140 serial number 38533 is a 1972 model.
You can buy the manuals direct from DEERE by calling 1-800-522-7448, and they will know which you need by the serial number.
The other post, Jim, must be smok'in some pretty good stuff, to come up with that post about the oiling system.
ALL the Kohler engine used in the 140's have the same splash oiling system.
What he posted is a partially correct description of the changes to the oiling system during the production run of the 2-cylinder Kohler KT-17 engine used in the 3137 tractors, and has absolutely NO bearing on the single cylinder K-301/K321engine used in the 140's.
Bob
08-10-2007 08:34:02
 Re: Info on John Deere 140 in reply to Bob, 08-10-2007 01:05:29
Heck, I can't even type "317"!
Jim Broughton
08-09-2007 21:59:43
Ron; The 140 JD is one of if not the best lawn/garden tractor made, in my opinion. If it has hydraulics and a rear PTO, even better. MY books are all out in the shop, so I'm using my foggy memory. I believe they were made from the late sixties toabout the end of the seventies.Rated at 14HP, the early ones had a "splash" sytem oiling on the Kohler motor, later one had a pressure oil system. That means the early ones were good on resonably level ground, not so good in hilly country. Mine is a 1971 model, splash sytem engine that has and does work hard for me ever since it was new! It was availble with a 48 inch mower deck, rototiller attachment, hydraulic front blade and a variety of other implements. Fact is, I till my 1/4th acre garden in "neutral" as the pTO tiller literall pushes the tractor through the field !! In the 36 years i've used mine, only a valve job, battery, and two new front tires !! They're great little tractors !! Have fun and good luck with her ! Jim B.
