Here goes...I have a JD A with a dltx 71 carb that will idle so low you think it is going to quit with every stroke it makes. I rebuilt the carb about a month ago. For some reason I can not get this tractor to run right. It surges whenever there is a load put on it. Even with no load, if I give it more throttle, it will surge like nobody's business. I ran and checked for the following: 1 At half throttle, no load, I closed both the idle and load needles. One at a time. With idle closed the tractor ran fine, no real noticable change in rpm etc. When I closed the load needle at half throttle the engine surged/throttled up and down like it was supposed to. 2 I disconnected the governor to throttle rod and verified it is 1/2 hole short of connecting to the throttle shaft on the carb 3 I used the proper number drills on the carb to clean it and dissasembled it this evening. I verified every passage was clean and all 4 tiny holes near the throttle plate are unclogged. 4 I visually inspected the float to make sure it was at the right level in the bowl. However I have not checked the fuel level in the bowl yet. Could this be a cause of surging when ever I move the throttle? I notice that sometimes when it starts to surge it will settle back down on its own sometimes. 5 I have replaced the throttle shaft, bushings, plate, and carb plate, all gaskets, float and everything else that needed to be replaced. I double checked my linkages and oiled them to make sure the were free of any binding. No binding found. 6 I removed the intake air pipe that goes to the carb thinking I had a clogged filter. No change in the way it runs, still surges. 7 I removed the gov to throttle linkage and throttled the tractor by hand. The tractor ran smooth as silk at high and low throttle throughout the entire rpm range. I am ruling out the govenor due to the fact that at low rpm the governor seems to be working fine. Any time there is a demand for throttle other than a good idle rpm the engine surges but eventually will settle down on it's own when not under a load. When under a load it never settles down it just gets worse. What am I missing. I suspect the carb is the problem. I have a dltx 18 carb that I put on this evening and the tractor seemed to run much better even though the dltx 18 needs to be rebuilt. This problem is about to drive me up the wall. If I put the tractor on the street and go up a slight hill in most any gear it will surge and sputter like it is not getting fuel or air... Thanks for taking the time to read this lengthy post.
Scott
