John Deere 237 on 3020
BenJ
08-09-2007 17:04:17
Hi! Guys I really like all the wonderful posts on this site. I have a question maybe you guys can help me with. I am looking at buying a 237 John Deere Mounted corn picker and I own a 3020 Gas Powershift row crop and it has 34inch rear wheels and the heavy cast centers will that corn picker fit on my tractor. Thank you for your help!
msb
08-09-2007 20:48:02
 Re: John Deere 237 on 3020 in reply to BenJ, 08-09-2007 17:04:17
Rims will have to be moved all the way out on the centers and the wheels moved all the way out on the axles unless your tractor has extra long axles.The 237 was the best picker ever built by anyone.Just don't let the husks build up on the tractor or the picker. Those gassers run very hot and are very prone to catch fire.
MSM
08-09-2007 20:32:13
We ran a 3020 years ago with a mounted 237. It had 15.5x38 rubber all the way out on the axles. It may work with the 18.4's ,but it is going to be real close. Also if you do use it make sure you have the raised extensions that go on in place of the side shields,otherwise it will heat up because the side screens get clogged up. Carry a big fire extinguisher,back when they were used on alot of the farms,one or two tractors always managed to catch fire every year,usually gassers with mounted pickers.
NE IA Dave
08-09-2007 20:04:22
I'm no expert, but there used to be all kinds of them on 3020's. I do not recall tire sizes etc. but I would guess a 99% plus chance it will.
In our area a 3020 with power shift did ok with snapping unit, but with a sheller on there wasn't any to much tractor in the hills.
Loren in Florida
08-09-2007 19:53:54
Should mount up just fine. We bought a 237 around 1970 and put it on our 730. The previous owner had had it mounted on his 4010 and 3020. I really liked that picker. Did a good job. I don't see any problems with your rear wheels, but I'm sure someone will respond if I'm missing something.
