720 diesel oil leak
steve duplechin
08-09-2007 11:44:56
My 720 D Standard leaks some oil on the flywheel side when I work it hard. The oil leaks out the bottom of the flywheel shield. The amount of oil that leaks out is between 1/2 cup to 1 cup. What do you think the problem could be.
buickanddeere
08-10-2007 09:45:01
 Re: 720 diesel oil leak in reply to steve duplechin, 08-09-2007 11:44:56
If air is blowing out the crankcase breather, the engine has too much blowby. The high crankcase pressure is pushing oil out. The crankcase is supposed to be under a slight vacuum.
Blksmok
08-09-2007 12:08:43
Steve...here's a list of possible causes. 1) thrust cover not centered properly around flywheel spacer, 2) seal inside flywheel spacer is bad, 3) oil return hole inside thrust cover is plugged, 4) oil too thin due to diesel fuel dilution 5) too much crankcase pressure forcing seal to leak, or 6) excessively worn main bearings causing "elliptical" motion when the crank turns. First four items are cheap repairs, #5 and #6 will cost more.
