oil pump
kendak
08-09-2007 07:51:20
Rebuilding 46 "A" & have two oil pump bottom plates [doner tractor]..one is smooth & the other has two machined concave grooves cut in it ...which one should I use & what purpuse does this serve...thanks ...Kent
P Browning
08-09-2007 12:56:29
 Re: oil pump in reply to kendak, 08-09-2007 07:51:20
What are the two part numbers of the pieces you have? Did you look them up in the Parts Catalog?
As I see it, there was only one oil pump bottom plate (P/N B247R) for all of the styled "A" tractors. And according to the picture of the cover in the Parts Catalog, those little concave grooves you refer to -- are there! (PatB)
kendak
08-17-2007 12:02:36
 Re: oil pump in reply to P Browning, 08-09-2007 12:56:29
thanks for help...flat plate [no grooves] came out of 37 model...Kent
