620 electrical problem
CJ1207
08-09-2007 07:46:02
Mass voltage drop on switch side of amp meter. It registers 12 volts on batery side and on switch side while switch is off. When switch is on ignition position, have 3 volts on switch side of amp meter with points open. When closed have no voltage. Of course same happens at batery pole on switch and ignition pole. Have no voltage at all in any position to any of the light poles on the switch at any time. Previously had mis-wired the ground wire to coil and had a pop and smoke from somewhere around the coil. Replaced switch and wired everything right and had all lights and correct voltage at coil with points open and tnen also when closed.
Does anyone here know if my trouble could be as simple as a bad coil? Also, am getting some voltage feed back through the safety ground out wire on the coil to the switch that registers about 3-4 volts as well. Can one burn out a prefectly good switch that easily? Anyone's thoughts are welcome. Thanks
Chris in MD
08-09-2007 08:59:56
 Re: 620 electrical problem in reply to CJ1207, 08-09-2007 07:46:02
Before we get lost here, I just wanted to say that your 620 should have a ballast resistor between the coil and the switch. This should drop the voltage to around 6 volts on the coil.
Maybe the drop you're referring to at the switch means you didn't put the resistor in.
BUT, then you say you have no voltage at the lights... so that's got to be the switch if it started there!
CJ1207
08-09-2007 09:20:07
 Re: 620 electrical problem in reply to Chris in MD, 08-09-2007 08:59:56
Chris, it has the ballast resistor inline between the switch and coil on the "hot" wire. With the points open, there should still be 12 volts to the hot side of coil. There is only 3. With the points closed there is none when it should read 5-6 volts. There is a ground wire that runs from coil to the ground on the switch. If I am getting feedback voltage through that ground wire, does it make any sense at all that the coil may have a short? I checked continuity on poles of the switch and have good continuity on all poles. Thanks
