410D Hydrolics
hughski
08-09-2007 07:24:26
Just purchased a house and a Deere 410D came with it. It has been sitting outside for 2 years. I finally got it started and sounds great with a little help of starting fluid to get it going. No hydolics though. Dip stick shows 3/4 full and no apparent hose leaks. Any ideas? Thanks
Jonathan in MA
08-09-2007 10:41:36
 Re: 410D Hydrolics in reply to hughski, 08-09-2007 07:24:26
This is a mid 90's 410D ?? I think some of the older s/n staright 410's (70's and early 80's) had a D in the s/n.... but either way..make sure the front shaft is turning and the shaft on the pump is actually turning... Also there is a destroke solenoid mounted on the pump that is energized while cranking that prevents the pump from building pressure during the start process. If thats stuck, it will prevent the pump from building any pressure.
hughski
08-09-2007 17:50:23
 Re: 410D Hydrolics in reply to Jonathan in MA, 08-09-2007 10:41:36
Thanks for the info. Is the pump you are talking about located just in front at the bottom of the the radiator? By the way, my 410D is a '74.
