How can I add fluid to my tires?
lekander883
08-09-2007 03:58:31
How does one go about checking the pressure and adding fluid if needed to his tires when there filled with fluid? One looks a little low. Thanks, Troy.
Earl-IL
08-09-2007 08:58:56
 Re: How can I add fluid to my tires? in reply to lekander883, 08-09-2007 03:58:31
I just filled my 35 "A" Deere with w. washer fluid.I bought the fill valve from Gempler. Washer fluid won't eat your rims like calcium but it is not as heavy. 8 lb. to the gallon. 13.6 36 held 48 gallon per side. I plowed with it in July and I am very happy with the traction ,compared to hang on weight. Earl In Illinois
Dave Sherburne NY
08-09-2007 07:16:29
There are special gauges for fluid filled tires still make sure you rinse it out GOOD or it becomes
one time use . On the link, the Quik fill tractor
tire attachment is the best. It lets the air out as
the fluid goes in.
Gary from Muleshoe
08-09-2007 04:13:42
Roll the tire so that the valve stem is at the top. Now check your air pressure. As for adding fluid you can get an adapter at your farm supply or tire store that allows you to hook up a garden hose so you can add fluid. Unless you have punctured you tire it is unlikely you have lost any fluid.
teddy52food
08-09-2007 05:46:36
 Re: How can I add fluid to my tires? in reply to Gary from Muleshoe, 08-09-2007 04:13:42
If you use a gauge, wash it out good or it will corrode and stick later.
