2120 Hydraulic troubles
R.Wuytenburg
08-08-2007 09:28:05
Am having troubles with the hydraulics.System will work fine for 10 minutes and then I have no hyd. power.Put a flow meter on the line from the filter from the oil transmission pump that feeds to the resoivoir to the high pressure pump and it drops down to 1-2 gpm.Have already checked the inlet strainer,hyd. filter etc.Have now taken the trans. pump out of the tractor and it looks fine.Can anyone point me in the right direction?Thank you.
Rob W.
Tx Jim
08-11-2007 04:26:12
 Re: 2120 Hydraulic troubles in reply to Vermont John, 08-08-2007 09:28:05
buckanddeere,may I ask what your point is in listing all those part #s? Are you impying that all those parts are required to repair this mans tractor? Also how will a "leaking check valve" effect pump pressure. I thought a "check valve" prevented a liquid from returning to sump. Also can you tell me what is a "floater" as I've never heard that term related to this problem. Thanks,Tx Jim
Tx Jim
08-10-2007 04:11:56
 Re: 2120 Hydraulic troubles in reply to Michael Satterwhite, 08-08-2007 09:28:05
Buickanddeere,I think there is no trans flow control valve on left side of case. There is a high pressure control valve on RH side of case close to hyd oil filter. Also to RW's original post, the stand-by pressure should be 2250 psi not 1800 psi. Also have you checked for an internal high pressure leak as I think that is where your problem lies? Tx Jim
buickanddeere
08-10-2007 07:40:35
 Re: 2120 Hydraulic troubles in reply to Tx Jim, 08-10-2007 04:11:56
I agree the front pump should be at 2250 and no flow if no high pressure hydraulic systems are being used. Flow control data as follows. Yes there is a difference between right and left.
1 U15415 O-RING 1 X X
2 R26375 O-RING 1 X X
3 R66085 BACK-UP RING 1 X X
4 R66084 FITTING 1 X X 3/4"
5 T13119 O-RING 1 X X
6 R39273 HOUSING 1 X X (ORD R26375, R66083, R66084, R66085, T13119)
R66083 HOUSING 1 X X
7 12H304 LOCK WASHER 3 X X 3/8"
8 19H1800 CAP SCREW 1 X X 3/8"X1-1/2"
9 R40072 SPRING 1 X X
Cart KEY PART NO. PART NAME QTY SERIAL NO. 2020 2120 REMARKS
10 R33521 SHIM 2 X X TK=0,75MM(.030")
11 R40562 APERTURE 1 X X
12 AR65881 VALVE 1 X X (SUB FOR R40561)
13 R26906 O-RING 1 X X
14 R31665 FITTING 1 X X 7/8"X3/4"
15 19H2128 CAP SCREW 1 X X 3/8"X3"
16 19H2552 CAP SCREW 1 X X 3/8"X1-1/8"
17 R39112 FITTING 1 X X 3/4"
18 R28776 O-RING 1 X X
buickanddeere
08-09-2007 21:10:13
 Re: 2120 Hydraulic troubles in reply to R.Wuytenburg, 08-08-2007 09:28:05
Check the transmission flow control valve that's on the outside left of the transmission case.
R.Wuytenburg
08-09-2007 15:06:37
Thank you to everyone that has responded to my hydraulic problem so far,but I can elaborate here with some more info.My tractor does not have the HI/LOW unit or the independent PTO.When I first started having troubles Ifirst looked at the inlet strainer and cleaned it.I also installed a new hydraulic filter/fluid.When the problem arose again I attached a pressure gage on both the low and the high pressure lines.I noticed that the low(150-200 psi)pump would drop off first and the high(approx. 1800 psi)pump would drop off shortly after(High pressure pump doesn't make any unusual noises).I assumed that this was because the resoivoir was empty that the tranny pump was supposed to fill up.I know that the tranny pump does many things(tranny gear lube,fill hyd.resoivoir etc.)but with no flow showing on the flow meter led me to believe that my tranny pump was no good.The pump looks fine.I have also inspected the steel inlet and outlet lines to the tranny pump and I can't see anything wrong with them.Could my bypass in the hydraulic filter be causing trouble intermittently?Any help would be appreciated.Thank you.
buickanddeere
08-10-2007 08:00:07
 Re: 2120 Hydraulic troubles in reply to R.Wuytenburg, 08-09-2007 15:06:37
After re-reading this, the evidence points to either a leak in the trans low pressure hydraulic system, a relief valve that is opening too low, a bypassing check valve, a floater somewhere on the suction side of the trans pump or something similar. The pump might just be tired and unable to make pressure with the required flow?
Tx Jim
08-09-2007 04:32:42
 Re: 2120 Hydraulic troubles in reply to mjbrown, 08-08-2007 09:28:05
As previously asked does it have ind. pto or hyd hi-lo? If so there are tubes feeding them from trans pump that can crack. Also check for leaking rockshaft control valves. Tx Jim
Bluepaint
08-08-2007 20:13:47
What is front pump like...."noisy" , I got a lot of trouble with valves on 2130's.
cannonball
08-08-2007 18:27:26
don't know if it has a hi lo or a hyd pto but the trans pump feeds those first...
MAY GOD BLESS THE USA
