320 shifter stick
720 in pa
08-08-2007 03:31:14
i need to repair the shifter on my 320.pulled it apart last night to see why lever moves from side to side excessively.appears the pin that keeps stick in line is worn bad,also hole in shifter cover where pin goes in is eggshaped.what is the proper way of repairing this? thanks
ram ranch
08-08-2007 15:51:18
 Re: 320 shifter stick in reply to 720 in pa, 08-08-2007 03:31:14
what if it's a late 320 where the shifter lever has a bend in it. unlike the 40s shifter?
Dave from Ohio
08-08-2007 05:03:29
Easiest thing to do is to replace the shifter quadrant. . . Ive seen them listed on e-bay from time to time selling anywhere from $30-75 plus shipping. I believe the shifter quadrant from a 40 is very similar to a 320 but I dont know for sure. . . dont quote me on that one. By the time you take out the forks, pins, etc and replace them in a new trans cover its easier just to replace the whole unit. (assuming the earlier 40 --much easier to come across-- unit is the same).
Mike M
08-08-2007 07:25:02
 Re: 320 shifter stick in reply to Dave from Ohio, 08-08-2007 05:03:29
But then wouldn't you likely get another one just as worn out or worse ? I'd hate to buy one without seeing it in person.
two cylinders saves gas
08-08-2007 18:47:13
 Re: 320 shifter stick in reply to Mike M, 08-08-2007 07:25:02
Thanks mike for the advice i got it soldered up with no mayjor problems .
Mike M
08-09-2007 05:10:02
 Re: 320 shifter stick in reply to two cylinders saves gas, 08-08-2007 18:47:13
Your welcome.
