JD 300
T Drewcock
08-07-2007 23:39:50
My Uncle has decided to give me his 197? John Deere JD 300 Loader/Backhoe. But it has some specific issues. 1)The block has been cracked and patched (proper repair?) 2)pin and bushings in hoe are loose (easy to find parts?) 3)Weight of machine (transporting may be an issue) I am greatful for the offer from him but I am looking to avoid a potential money pit. Not that equipment are not a money pit HaHa.
Mike M
08-08-2007 10:29:43
 Re: JD 300 in reply to T Drewcock, 08-07-2007 23:39:50
I'm guessing weight of 10,000 to 12,000 lbs so it will take at least a 3/4 or 1 ton truck and a really good trailer.
Any of that stuff is going to be a money pit,but at least you can start off at the RIGHT price. If you have any use for it all the better. I would for sure get it and maybe ask before hand about if it doesn't work out or looks like it is getting to be too big of a money pit how he would feel if you had to sell it. Or pay him something for it upfront and own it outright with no strings attached. He may just be using you to fix it up then ask for it back later. BTDT I tried to buy an air compressor off my uncle but he wouldn't sell. Said I could use it though. Trouble was I did put some time and money in it to keep it going. One day he said he needed it and came and got it back. He really didn't use it and now it is sitting out going to pot again ! I at least keep it under cover. I still probabally came out better off than had I rented one. Live and learn. Sounds like you may be headed down the same path ?
T Drewcock
08-08-2007 21:52:46
 Re: JD 300 in reply to Mike M, 08-08-2007 10:29:43
My uncle has told me that when I am done with it that I can sell it or give it to a neighbor. He just doesn't want to see it back in his yard. So I don't think I have to worry about him wanting it back. My biggest concern is availablity of parts.
Mike M
08-09-2007 05:13:27
 Re: JD 300 in reply to T Drewcock, 08-08-2007 21:52:46
I'd say you better snatch it up then. Normal parts should be easy to get as that is the same as the farm tractor. Some of the specilaty parts may be found new and used ? Should be some of those parted out.
T Drewcock
08-09-2007 22:57:15
 Re: JD 300 in reply to Mike M, 08-09-2007 05:13:27
Thanks for the advice. I'm sure we will be chatting again.
jdemaris
08-08-2007 09:37:55
300 is a very well built machine - basically just an Ag. 1020 farm tractor painted yellow - and has better hydraulics. But, being around 40 years sold, it going to have some wear and tear.
They were prone to cracking the engine block in front where the front loader bolts on. Also, the backhoe has a single-cylinder swing arrangement that tends to break linkage.
Parts are easy to get, new and used.
T Drewcock
08-08-2007 21:58:28
 Re: JD 300 in reply to jdemaris, 08-08-2007 09:37:55
Thanks for the info. Have you aver heard of someone repairing the crack in the block? Do you have some links for parts websites or email adresses of people selling parts? By the way, if I gave you a VIN number would you be able to decipher model year. Also what's the difference between a 300 and a 300b Thanks again.
jdemaris
08-09-2007 05:36:30
 Re: JD 300 in reply to T Drewcock, 08-08-2007 21:58:28
You didn't mention where the block is cracked. If it's cracked in front where the front loader bolts on - I've seen many that are patched up - but that's never going to be as strong as original unless you add some extra side-frame supports. The engine is very common and used in many other machines including 350 crawlers, 380 forklifts, power units, 820-830-1020 farm tractors, etc. As to giving links to websites with parts - try this site for one. Deere parts are available many places - there is NO shortage new or used. I've got a 300 sitting in my shop right now - it's a 1968 model with Tractor serial # T4P1C 076470T and engine serial # M41TP 117367T. It has a 9250A backhoe on it. With differences in later 300s, at some point the 300 got a four cylinder engine instead of the three cylinder - I know the 300D is four cylinder. The first 300s have three cylinder 152 diesels or 135 gas engines. 300 Deere backhoes are very popular. Many have power steering, power brakes, hydraulic reverser, etc. Non-running junkers tend to bring well over $3000 in my area of New York. I just offered $2500 for a 300 with hoe that had a blown engine. I didn't get it, somebody else paid $3500 for it. If you being offered one for free - what's the problem? Seems you can't lose unless you dump $10,000 into it and then sell it for $5000. It's probably worth at least $3000 as it is - even if it doesn't run.
T Drewcock
08-09-2007 23:07:24
 Re: JD 300 in reply to jdemaris, 08-09-2007 05:36:30
Thanks for the advice. I don't suppose you know off the top of your head what one of these late 60's 300 weighs (for transport purposes) Thanks again for all the great input. I'm sure we will be chatting again.
jdemaris
08-10-2007 05:54:06
 Re: JD 300 in reply to T Drewcock, 08-09-2007 23:07:24
I can make a good guess. A bare 300 diesel tractor weighs around 4900 lbs.
I have a small Ford 4000 backhoe about the same size as the Deere 300 - and the Ford tractor itself is 1000 lbs. lighter even though it has a bigger engine and more horsepower. My Ford with the hoe and loader weighs 6800 lbs. So, figure the Deere is at least 1000 lbs. more - but since it's a bit more rugged, I'd put the total 300 hoe/loader weight at 9000 lbs. (approx.)
Mike M
08-09-2007 07:56:18
WoW ! That $3500 junker makes the 300B with only 2700 original hours and new tires I saw advertised sound like a real deal.They wanted $7850 I think.
jdemaris
08-09-2007 10:54:43
 Re: JD 300 in reply to Mike M, 08-09-2007 07:56:18
I don't find it surprising at all. I've come across several beat-up used hoes recently - JUST the backhoe attachments themselves - and they were priced over $2000. I just offered a guy $1200 for a very ratty looking 33 hoe off a Case 580CK and he didn't take my offer. Also seen many Deere hoe take-offs - from the early 70s priced over $2000. In fact, I've been looking for years - for a "cheap" hoe attachment that will fit my 1960 Deere 1010 crawler-loader. Found one last month - it was parked in some guy's barnyard - attached to a 350 crawler-loader with a price tag of $3800 on it. I stopped and asked if he'd sell JUST the hoe - and found out the $3800 asking price IS just for the hoe attachment (I figure he's nuts). Small running backhoes seem to bring better prices than the big ones. I bought a big 1967 18,000 lb. Pettibone Mulitihoe with Detroit Diesel power for $2300 in good running condition - but it went cheap because it's too big to truck for most people, and too slow to drive down the highway. I think, for the most part, the days of $1000 beat-up but running backhoes are gone. And, popular brands with good parts support bring more - and Deere is one of the most popular - for a small machine. A 300 Deere - just the bare tractor often sells for $3500 to $6000 depending on condition. With later model hoes - e.g. Deere 300B, Fords, JCBS, Case 580s, etc. - in good working condition - I see many in the $8000 to $11,000 price ranges.
buickanddeere
08-09-2007 21:15:31
 Re: JD 300 in reply to jdemaris, 08-09-2007 10:54:43
Sounds right. I paid over $4,000US for a complete model 10A backhoe to use on my 1640. Still had to purchase six mounting plates, a closed center conversion valve and supply-return hose/fittings.
